Processes stopped
Hi - we're seeing something like this. Did you find a fix?
Mike
--- In vantage@yahoogroups.com, "too_much_hg" <neil_willet@...> wrote:
> I agree that ping -t servername is a good start.
> I also recommend double checking the network setting at the servers and the switch. I have seen instances where having them both set to AUTO will cause periodic network delays due to "Re-negotiation".
> I always force my switch port settings and server port settings manually and have found this to be much more stable. <assuming good cabling and hardware>
> When in doubt there is always Performance Monitor.
> Good Hunting !
> Neil
> --- In vantage@yahoogroups.com, "tanya_denison" <tdenison@> wrote:
> > We are having a problem with printing where every active process suddenly stopped. Pick slips, invoices, packing slips all stopped printing.
> > I was able to get things going again by stopping and restarting the processserver and taskagent appservers in the PET. But this only fixed things for 10 minutes, then things stopped again. I stopped and restarted 3 times and it would get things moving for another 10 minutes.
> > The Task Agent log has the following at the point of failure:
> > [12/11/27@10:43:08.279-0800] P-007028 T-005640 1 AS -- (Procedure: 'createTaskInstance agent/TaskAgent.p' Line:2124) Disconnecting database Epicor905 due to server communication failure (14959)
> > We are currently working with Epicor support, but I wanted to get input this group as well. Where would we go to look for what is causing this problem? Have you seen problems like this before?
Your DB and App servers on the same machine?
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
<http://www.usdoingstuff.com>
No, our appserver is on one box, with SQL Server on another.
Tanya Denison | IT Manager | NRS, Inc.
2009 S. Main Street, Moscow, IDÂ 83843
tdenison@... | www.nrsweb.com
c: 208.301.0599 | p: 208.883.7834 Ext 277 | f: 208.882.1744
Of Jose Gomez
Sent: Tuesday, November 27, 2012 11:30 AM
To: Vantage
Subject: Re: [Vantage] Processes stopped
*Jose C Gomez*
*Software Engineer*
E: jose@...
printing.
> database
I've seen this once when we restored LIVE to Test/Pilot and fired up
Test/Pilot and forgot to change the appserver port mapping is SysAgent.
Tanya Denison
Sent: Tuesday, November 27, 2012 2:35 PM
Subject: RE: [Vantage] Processes stopped
2009 S. Main Street, Moscow, ID 83843
tdenison@... <mailto:tdenison%40nrsweb.com> | www.nrsweb.com
Behalf
Of Jose Gomez
To: Vantage
*Jose C Gomez*
*Software Engineer*
E: jose@... <mailto:jose%40josecgomez.com>
<mailto:tdenison%40nrsweb.com> >
printing.
> database
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2012.0.2221 / Virus Database: 2629/5422 - Release Date: 11/27/12
Hmm have you checked your connectivity between the machines? What does your
ping look like / latency etc?
ping -t YOURSQLSERVER
Also make sure that the date / time on both matches the AD server
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Of Jose Gomez
> To: Vantage
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> printing.
> > database
That was my first brief thought, but this happened suddenly in the middle
of usage in production.
*Tanya Denison* | IT Manager | NRS, Inc.
*2009 S. Main Street, Moscow, ID 83843*
*tdenison@... *|* www.nrsweb.com*
*c: 208.301.0599* | *p: 208.883.7834 Ext 277 *|* f: 208.882.1744*
*From:* vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] *On Behalf
Of *Vic Drecchio
*Sent:* Tuesday, November 27, 2012 11:38 AM
*To:* vantage@yahoogroups.com
*Subject:* RE: [Vantage] Processes stopped
Tanya Denison
tdenison@... <mailto:tdenison%40nrsweb.com <tdenison%40nrsweb.com>>
| www.nrsweb.com
<mailto:vantage%40yahoogroups.com<vantage%40yahoogroups.com>
Behalf
Of Jose Gomez
To: Vantage
*Jose C Gomez*
*Software Engineer*
E: jose@... <mailto:jose%40josecgomez.com <jose%40josecgomez.com>>
printing.
> database
http://groups.yahoo.com/group/vantage/files/.<http://groups.yahoo.com/group/vantage/files/>
Thank you, I will check on this once we are off the call with Epicor
support.
Of Jose Gomez
Sent: Tuesday, November 27, 2012 11:39 AM
To: Vantage
your ping look like / latency etc?
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Behalf Of Jose Gomez
> To: Vantage
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> printing.
minutes.
> > database
> and Crystal Reports and other 'goodies', please goto:
Tanya, curious if you've found the problem and resolved it via Epicor
Support..?
Tanya Denison
Sent: Tuesday, November 27, 2012 2:50 PM
support.
Behalf
Of Jose Gomez
To: Vantage
*Jose C Gomez*
*Software Engineer*
> To: Vantage
> *Jose C Gomez*
> *Software Engineer*
> printing.
minutes.
> > database
Well, kind of. By the time we started a call with them, the Task Agent was
completely locked up and could not be started or stopped. So they had us
restart the main appserver, which did not resolve the issue. Then they had
us restart the application server and the database server.
This got us going again in the same way as me stopping and restarting the
task agent did � in 10 minutes we were stuck again. The next time we
stopped and started again seemed to hold.
However, this leaves us in the position of not knowing why this happened,
and how to avoid it in the future. 3 hours of downtime in a distribution
environment the week of Cyber Monday isn�t good.
I really appreciate all the ideas we got from this group!
Of *Vic Drecchio
*Sent:* Tuesday, November 27, 2012 1:47 PM
Support..?
Tanya Denison
support.
| www.nrsweb.com
Behalf
Of Jose Gomez
To: Vantage
*Jose C Gomez*
*Software Engineer*
| www.nrsweb.com
> From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com<vantage%40yahoogroups.com>
> To: Vantage
> *Jose C Gomez*
> *Software Engineer*
> E: jose@... <mailto:jose%40josecgomez.com<jose%40josecgomez.com>>
> printing.
minutes.
> > database
Good Hunting !
Neil
We had a similar issue, I ended up with a dedicated switch/Nic between the two servers.
Are they virtual or hardware servers? If they are virtual are you backing up the VM's? When the VM is replicated it momentarily breaks the connection between servers.
Hope this helps...
Chris Wineinger
ERP Specialist
Interior Systems Inc.
> support.
> Of Jose Gomez
> To: Vantage
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > To: Vantage
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > printing.
> minutes.
> > > database
