Product Configurator - 9.05.700C
The configurator is called via Business Objects so you could build a .net project calling them in a stand alone application.  You would still need to connect to the Epicor database though and your application would consume a license while in use.  The configurator has to store the results in a record tied to either a quote line, job or an order line.  Which means your external use of the configurator has to include creating an order and/or linking to an existing quote, job or order.
I know there are companies out there using the configurator via the Web.
Jim Kinneman
Encompass Solutions, Inc
Has anyone tried to make their Product Configurator an offline tool?
Is this even possible?
Manasa
