Was wondering if the hive mind can help, I was asked to do a report about labour adn jobs costs and setting up cost and Production Detail report fits the bill for finance, is there away to run this report say for current active jobs and output it to a csv. Or as crack this into a BAQ ive looked at doing it myself and it this a massive job to do.
Or even if there is another way of getting the same information.
You can always use standard reports and change the output format to Excel or csv. You mileage may vary depending on the output.
Other option is to build a dynamic criteria report with a simple baq or a BAQ report to get simple column output of the data, that would export to excel or csv in a cleaner fashion.
The other option if there is no need for a report, would be just use the BAQ and use BAQ export… Although I can’t recall when they introduced that… You may have it in your version or not. You can schedule a BAQ Export, just like you can a report.
Best place is the ice tools and customisation guides on Epicweb. You will need to look at the archived versions for the documents, 10.2.500 is getting a bit long in the tooth.
