Patty
You are right, it does not show any COR or credit values on the Sales
Gross Margin Report
It only takes Sales Value and COS figures from the invcdtl table
(Invoice lines)
On a credit invoice line, the COS fields always show zero, as these are
usually generated by a shipment. The COR is in a separate tables.
In the past we have had to write a crystal report to show Shipment
invoices against invoice line COS and credit notes against the linked
RMA disposition in order to get it to reflect the P and L GM.
Gary
Of bpbuechler
Sent: 30 September 2008 13:46
Subject: [Vantage] Re: Profitability on RMA Rework Job
Okay...at the point of dispostiion is when the COR hits. But my
question is why does it now show on the Sales Gross Margin report.
My steps are as follows:
My RMA is linked to a Sales Order Line/Release. When I dipositioned
the return, I choose back TO JOB (not FAIL). The per unit cost
buckets displayed a value and I didn't change them as they were
correct. It all went back to the Job on the WIP Material side (not
distributing it back to the costing buckets. I processed the Credit
and completed/closed the job. I then ran Capture and the WIP
Material cost is doubled.
My question is why does it not show the COR and Credit on the SGM?
Why are the costs double value?
How can I accurates show Sales Gross Margin when it does not include
these transactions?
Patty Buechler
"Gary Parfrey" <garyp@...> wrote:
Behalf
40yahoogroups.com> ] On
Gross Margin Report
(Invoice lines)
Gary
Of bpbuechler
these transactions?
Patty Buechler
>is
> Patty
> There is no COR (Cost of Return) incurred at time of receipt. Cost
> only incurred at point of disposition in Vantage. If you have a CORcredited
> account it goes there, else it goes to COS.
> One issue is that the cost can be overridden by the user in the
> disposition screen. I suppose depending on whether you have
> the customer, is whether you enter zero cost or enter an actualcost.
>[mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> Gary
> Dot Net IT Limited, Reg No 4412519
Behalf
> Of bpbuechlerthe
> Sent: 29 September 2008 16:33
> Funny...I just opened a call with Epicor on this very subject.
> When I receive an RMA I have two choices for disposition...FAIL
> (which would be to DMR) or back to JOB. In the scenario below...I
> assume you are going back to the JOB.
> We have the same question/issue as you do.
> What happens to COS $'s at the point of Receipt of the RMA?
> It would seem silly to have to do Job Cost Adjustment when the
> program is smart enough to know the value of each cost bucket at
> point of Receipt of the return. If the original sale and cos was byGL
> product group (GL Accounts) and if I don't have a Cost of Returns
> Account associated to the Product Group, does this make the<mailto:vantage%40yahoogroups.com> ,
> difference?
> Bottom line...Why does the Receipt of the RMA not reduce the SGM?
> Thanks
> Patty Buechler
> "Geary, Stephanie" <sgeary@> wrote:receive
> > I don't really know if this is your problem... but when you
> an<mailto:vantage%40yahoogroups.com>
> > RMA part it is valued at the cost your COS had incurred when it
> shipped.
> > So if your cost of sales was 1000 it would receive it back into
> > inventory at 1000. and if you sent it to a work order to be
> reworked
> > that value would of course follow it to the work order.
> > ________________________________
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com><mailto:vantage%
> Behalf<mailto:vantage%40yahoogroups.com>
> > Of Randy
> > Sent: Thursday, September 25, 2008 5:00 PM
> > Subject: [Vantage] Re: Profitability on RMA Rework Jobjob
> > That's my question exactly - how can it 'appear' to cost $1,000.
> How
> > is it that you 'treat it as zero'?
> > We simply process the RMA, it goes right into the job. We apply a
> > small amount of labor and/or material and ship it back out, but
> > Vantage thinks that the cost is $1,000 because the parent part is
> > also a component on the job, so it is effectively charging the
> > for the cost of the parent.fiz
> > I think it's because we don't issue a credit, but are we the only
> > company who doesn't bother with crediting and re-invoicing. The
> > is so small that it's not worth the extra effort.<mailto:vantage%40yahoogroups.com>
> > Anybody else with this experience?
> > thanks,
> > Randy Weber
> > IT Manager
> > TLC Electronics
> <mailto:vantage%40yahoogroups.com> ,our
> > Robert Brown <robertb_versa@>
> > wrote:
> > > How can your RMA returned (for repair) part cost be $1,000?
> > > Do you credit the customer account for the return (and is your
> > sales revenue account knocked down for the return) - and then not
> > rebill them (full $1000 + labor & parts) upon repaired product
> > shipment?
> > > We treat RMA material sent to us for repair as zero value (and
> > technically still the customer's ownership even though it is in
> > hands). Even if it is a no charge (warranty or goodcustomer 'good
> > will') repair, the only costs incurred on the repair job are theRMA
> > labor and any replacement parts we might use.
> > > Seems to me you have to do some inventory value and/or Job cost
> > adjustments so you don't take the hit on the full value of the
> > returned material (since it really didn't cost you anthing andyou
> > were paid for it already on the original sale).<mailto:vantage%40yahoogroups.com>
> > > Has to be a comptroller out there that has dealt with this and
> has
> > a vantage process solution... (??)
> > > Rob Brown
> > > --- On Thu, 9/25/08, Randy <rweber@> wrote:
> > > From: Randy <rweber@>
> > > Subject: [Vantage] Profitability on RMA Rework Job
> <mailto:vantage%40yahoogroups.com>an
> > > Date: Thursday, September 25, 2008, 3:14 PM
> > > Vantage 6.10.543
> > > When we rework a job that has come in under an RMA, the
> > Profitability
> > > and COGS goes out of whack.
> > > Example:
> > > Part cost is 1,000 and sold for $2,000. We take the part in on
> > RMAis
> > > and perform a small amount of rework - say $10.00.
> > > The job cost ends up being $1,010, and the rework sales order
> > forthe
> > > zero dollars so my profitability looks like we lost $1,010 on
> > job[Non-text portions of this message have been removed]
> > > and my COGS goes up accordingly.
> > > Am I missing something?
> > > Randy Weber
> > This message has been processed via your triumphgroup.com e-mail
> > address.
