Actually you might have to go one step further. I had this problem with two
same model notebooks on the same connection but with two different network
cards. In the properties of the card there is an Advanced tab and under
that is a bunch of things I usually ignore, but there is a Line Mode that
defaults to AutoDetect. For some reason the one card wasn't autodetectiong
the right mode so I had to set it manually to Full-Duplex or Half-Duplex
depending on the Hub or the Switch or the time of day (I'm not sure about
the last one). That's when I learned there was 2 kinds of Hubs. Also in
that Tab is line speed and the default is autodetect. You might want to
check that also.
Sent: Wednesday, January 24, 2001 12:54 PM
To: 'vantage@egroups.com'
Subject: RE: [Vantage] Re: Program Takes Forever to Launch
Seeing as a couple of others are having similar problems to what we had,
maybe it would be helpful if I explained further. The actual problem was
that one of our two switches was detecting our hubs as full duplex devices
(there are such a thing as full duplex hubs, but ours are not). All of our
network equipment is SMC, so I'm not sure why the switch could not detect
the hubs properly. In any case, plugging the hubs into the second switch,
where they were rightfully detected as half duplex, was what ended up
solving the problem.
Brian
<http://rd.yahoo.com/M=168002.1291681.2888959.2/D=egroupmail/S=1700007183:N/
A=564957/*http://www.columbiahouse.com/gateway?token=7416> Choose 3 DVDs for
$0.49 each!
Choose 3 DVDs for $0.49 each!
<http://us.adserver.yahoo.com/l?M=168002.1291681.2888959.2/D=egroupmail/S=17
00007183:N/A=564957/rand=692054020>
To unsubscribe from this group, send an email to:
vantage-unsubscribe@egroups.com
check that also.
Brian
> We have had the same problem here, but it was our switch.eGroups Sponsor
> have had 2 of
> them go bad. We use allied telesyn equipment and have not
> had a problem
> until the last 2 months. I will check our hubs as well, as I am still
> experiencing similar issues as Brian
$0.49 each!
