Unfortunately in E9 there is no actual pop-up. I have a text box that is labeled Error Messages and populate that with the errors/messages. Some others on the list may have a better solution, but I could never get it to work myself. E10, I pop-up all kinds of fun things because you can create your own forms with C# and that has opened a whole new arena.
Brenda
Sent: Wednesday, July 15, 2015 10:12 AM
Subject: Re: [Vantage] Progress 4gl Array
Thanks Brenda, one last question about your code. How do you display your warning message(setMsg) to the user in the configurator? I do love your message. I may have to implement something like that in ours!
On Wed, Jul 15, 2015 at 8:55 AM, brenda mohr brenda@... [vantage] <vantage@yahoogroups.com> wrote:
You can get creative with it. Here is an actual example from my configurator where I am calculating the total weight of all cores on a particular quote:
DEF VAR aBoxQP AS DECIMAL EXTENT 200.
DEF VAR amyWeight AS DECIMAL EXTENT 200.
DEF VAR i AS INTEGER INIT 1.
FOR EACH PcInValue WHERE (PcInValue.Company = (GetCurrentCompany())) AND (PcInValue.QuoteNum = setQuoteNum) no-lock.
IF (PcInValue.QuoteLine > 200) THEN DO:
setMsg = "SERIOUSLY!??? You quoted more than 200 Boxes?? Abort, Go See Brenda".
idiot = TRUE.
END.
IF (NOT idiot) THEN DO:
IF (PcInValue.InputName = "decCavPP1") THEN aBoxQP[PcInValue.QuoteLine] = integer(PcInValue.InputValue).
IF (PcInValue.InputName = "humdecCavWt1") THEN amyWeight[PcInValue.QuoteLine] = decimal(PcInValue.InputValue).
END. /*** idiot check ***/
END. /*** PcInValue ***/
i = 1.
DO i = 1 TO setTotBox:
myWeight = myWeight + (amyWeight[i] * aBoxQP[i]).
END.
Brenda
Sent: Wednesday, July 15, 2015 8:41 AM
Thanks!
Is the only way to assign initial values like the following:
myVariable[1] = 10
myVariable[2] = 20
Can I not do something like javascript: array-name = [item1, item2, ...];
On Wed, Jul 15, 2015 at 8:33 AM, brenda mohr brenda@... [vantage] <vantage@yahoogroups.com> wrote:
Here is a very basic example:
DEF VAR myVariable AS INTEGER EXTENT 5.
DEF VAR mySum AS INTEGER INIT 0.
myVariable[1] = 10
myVariable[2] = 20
myVariable[3] = 30
myVariable[4] = 14
myVariable[5] = 15
DO i = 1 TO 5:
mySum = mySum + myVariable[i]
END.
Brenda
Sent: Wednesday, July 15, 2015 8:14 AM
Subject: [Vantage] Progress 4gl Array
Can anyone tell me how to do an array in progress 4gl? I can't seem to get the syntax right. I just want to declare an array and assign it a few initial values. Thanks.
Jeff & Stephanie Purvis
