I copied the following from a posting made by someone else that I found in my message archive.
-Todd C.
Summary:
PG ClientTimeOut available with 9.1D
Details:
Page 2271MPS
timeout time out Clienttimeout
XA520
XA600
XA610
HOW TO SETUP THE PROGRESS ClientTimeOut
With Progress 9.1D03, Progress has made available a timeout feature.
To implement the feature the following lines must be added to the Startup
registry key on the server. This process applies to all clients connected to
the database.
Where 'n' is the number of minutes after which the user will be disconnected
if there is no activity. Again, this is a server parameter so all users will
be affected by this setting. Activity is defined as mouse and keyboard
activity from client to server.
This ClientTimeOut parameter can be put into the registry of the following
key, by default this key will not exist so will need to be created.
HKEY_LOCAL_MACHINE\SOFTWARE\PSC\PROGRESS\9.1D\STARTUP
Once you open the Startup Key, from the top select EDIT > NEW > STRING. The
string name is called "ClientTimeOut" in the value field put in how many
minutes till disconnection.
Once the changes have been made you will need to reboot the server for
progress to reread the registry on startup of the Admin Service.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of joshvantage
Sent: Friday, July 14, 2006 10:46 AM
Subject: [Vantage] Re: Progress 9.1D license timeout - anyone doing this?
I keep reading about the "Progress Registry Setting" But I cant find
what the setting is or instructions on what to change. Does anyone
have a link to this?
-Todd C.
Summary:
Details:
Page 2271MPS
XA520
XA600
XA610
the database.
--- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com, "Todd Caughey" <caugheyt@...> wrote:
> When it times out the user sees a series of disconnect type error
messages. Our usual routine it to pound on the enter key until a
different one comes up specifically asking you to press the space
bar. Not very "graceful" but not difficult and you sure know when
you have been timed out (a little reenforcement to get people to
logout if they ar enot using Vantage). Does not hurt anything and
any mid-stream transactions are backed out as if you had clicked on
the "X" in the corner of a screen.
> We have ours set to 2 hours which is working pretty well. Also,
if a user PC crashes and leaves a ghost session that ghost will
expire in two hours (with no messages). There are times when I
would like to set the limit to 1 hour to get rid of ghost sessions
sooner but it is a trade-off between license usage and user
inconvenience.
> As noted, selected users are let in on the secret of using Office
Data Collection to keep their sessions alive indefinitely.
> -Todd C.
> From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com [mailto: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com]On
Behalf Of hoomail4me
> Sent: Monday, April 10, 2006 1:21 PM
> To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
> Subject: [Vantage] Progress 9.1D license timeout - anyone doing
this?
> With the help of Aaron, I have become aware of a Progress registry
> setting that will allow for Progress license timeouts.
> Is anyone doing this and if so are there any related problems. I
> assume that Vantage will "gracefully" exit when the Progress
license
> times-out.
> Thanks,
> Bill
must have already linked your email address to a yahoo id to enable
access. )
Builder and Crystal Reports and other 'goodies', please goto:
http://groups. <http://groups.yahoo.com/group/vantage/files/.> yahoo.com/group/vantage/files/.
http://groups. <http://groups.yahoo.com/group/vantage/messages> yahoo.com/group/vantage/messages
http://groups. <http://groups.yahoo.com/group/vantage/links> yahoo.com/group/vantage/links
> SPONSORED LINKS
> Manufacturing < http://groups. <http://groups.yahoo.com/gads?> yahoo.com/gads?
t=ms&k=Manufacturing+software&w1=Manufacturing+software&w2=Membership
+database+software&w3=Database+mortgage+software&w4=Pda+database+soft
ware&w5=Database+management+software&w6=Database+marketing+software&c
=6&s=188&.sig=OG5F3819UOUOg63i0bu6kA> software Membership
t=ms&k=Membership+database+software&w1=Manufacturing+software&w2=Memb
ership+database+software&w3=Database+mortgage+software&w4=Pda+databas
e+software&w5=Database+management+software&w6=Database+marketing+soft
ware&c=6&s=188&.sig=N5BGdur84p-jyuOomcQdbQ> database software
Database < http://groups. <http://groups.yahoo.com/gads?> yahoo.com/gads?
t=ms&k=Database+mortgage+software&w1=Manufacturing+software&w2=Member
ship+database+software&w3=Database+mortgage+software&w4=Pda+database+
software&w5=Database+management+software&w6=Database+marketing+softwa
re&c=6&s=188&.sig=8rvcSQnCqJhTCZu-0Si39A> mortgage software
> Pda < http://groups. <http://groups.yahoo.com/gads?> yahoo.com/gads?
t=ms&k=Pda+database+software&w1=Manufacturing+software&w2=Membership+
database+software&w3=Database+mortgage+software&w4=Pda+database+softw
are&w5=Database+management+software&w6=Database+marketing+software&c=
6&s=188&.sig=u3KQrTRPAQfsWIT39aHDkg> database software Database
t=ms&k=Database+management+software&w1=Manufacturing+software&w2=Memb
ware&c=6&s=188&.sig=R3CF3ODPY4gwjDZjykQYvw> management software
t=ms&k=Database+marketing+software&w1=Manufacturing+software&w2=Membe
rship+database+software&w3=Database+mortgage+software&w4=Pda+database
+software&w5=Database+management+software&w6=Database+marketing+softw
are&c=6&s=188&.sig=lmBkRUiBtvHI1u5dkymDcw> marketing software
> _____
> YAHOO! GROUPS LINKS
> * Visit your group " vantage
< http://groups. <http://groups.yahoo.com/group/vantage> yahoo.com/group/vantage> " on the web.
> * To unsubscribe from this group, send an email to:
> vantage-unsubscribe <mailto:vantage-unsubscribe%40yahoogroups.com> @yahoogroups.com <mailto:vantage-
unsubscribe@ <mailto:unsubscribe%40yahoogroups.com> yahoogroups.com?subject=Unsubscribe>
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service < http://docs. <http://docs.yahoo.com/info/terms/> yahoo.com/info/terms/> .
> _____
