Progress BI file size question
We have had trouble with our b1 file increasing in the past and along with speed issues we resolved both of them with a dump and load.
However, just to confirm we run MRP daily and our file size can stay the same for weeks so not sure about MRP having an effect.
You can get a bi file monitor from Epicor that records the file size every few seconds so you can see when it increases so this gives you an idea of where to look in your server logs in case anything stands out as the cause too.
Hope this helps.
--- In vantage@yahoogroups.com, "b_ordway" <cooner_55421@...> wrote:
> > Does your company use MRP?
> Yes but I was pretty sure MRP volume has been about the same for quite a long time.
> I'll start there.
> If it's not MRP I wonder if some process might have changed or been added & how I might track it down.
> --- In vantage@yahoogroups.com, Travis McMullen <tmcmullen@> wrote:
> > I've always been told that running MRP increases the size of the B1 file.
> > I'be never seen the file reduce itself automatically.
> > Sent from my iPhone
> > On May 5, 2012, at 12:02 PM, b_ordway <cooner_55421@> wrote:
> > Hi,
> > Just doing some maintenance today and was wondering about a B1 file size.
> > This morning the Progress files sizes are B1 - 7.3 GB and D1 - 2.3 GB
> > I last used truncate about two weeks ago on 4/17.
> > 7.3 GB is about 2GB larger than I'm used to seeing.
> > The past two months B1 has been larger than I am used to.
> > Just wondering where I might look for the source of B1 increases?
> > As I understand it, the B1 grows only when necessary and will not reduce it
> > size automatically.
> > Running V8.03.409C - OE101B.
> > Thanks
Hi,
As I understand it, the B1 grows only when necessary and will not reduce it size automatically.
Sent from my iPhone
On May 5, 2012, at 12:02 PM, b_ordway <cooner_55421@...> wrote:
Hi,
size automatically.
I'll start there.
> Sent from my iPhone
> Hi,
> size automatically.
> Thanks
