Progress Explorer - Ver 5
Skip progress explorer and use procontrol.
Tim Care wrote:
> We have a test server setup and are working on Version5
> testing. When we relocated last weekend, we brought the
> test server back up, and now can't get the Progress Explorer
> to run. It gives a message saying
> Can't connect to Admin Server. Please make sure the Admin
> server is running (8836).
> In Control Panel, Service, it says the Admin service for 9.1a is
> running, but when I dug a little deeper, I found some files that have
> todays date, with a message that says it can't find a file. The message
> is :
> Exception at Wed Mar 28 11:41:56 EST 2001: java.io.FileNotFoundException
> Message (throw): Failure in instantiating AdminServer
> Message (excp): d:\epic50\Progress\AdminServerPlugins.dat
> Stack Trace:
> java.io.FileNotFoundException: d:\epic50\Progress\AdminServerPlugins.dat
> at java/io/FileInputStream.<init>
> at java/io/FileReader.<init>
> at com/progress/chimera/adminserver/AdminServer.getPluginInfo
> at com/progress/chimera/adminserver/AdminServer.setupPlugins
> at com/progress/chimera/adminserver/AdminServer.<init>
> at com/progress/vj/ntadminserver/NTAdminServer.<init>
> at java/lang/Class.newInstance
> at com/progress/chimera/adminserver/OSSpecific.getAdminServer
> at com/progress/chimera/adminserver/AdminServer.main
> Which file is it missing? How can I get this running again? Any help
> or suggestions would be greatly appreciated. I basically have until
> Friday to get this up and running. Thanks in advance.
> Tim Care
> Electro Chemical Finishing
> To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please go to: http://groups.yahoo.com/group/vantage/files/. Note: You must have already linked your email address to a yahoo id to enable access.
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
is :
Stack Trace:
Tim Care
I've encountered the same problem. We were going to upgrade straight from 3
to 5 but decided to use Version 4 for now.
Sent: Wednesday, March 28, 2001 10:58 AM
Subject: [Vantage] Progress Explorer - Ver 5
is :
Stack Trace:
Tim Care
