Bingo!  That's slick.  Thanks, William. This whole export process will be much more reliable than my previous method.  I like it.
Troy Funte
Liberty Electronics
            Troy Funte
Liberty Electronics
----- Original Message -----
Sent: Monday, November 26, 2001 5:28 PM
Subject: Re: [Vantage] Progress Exports (was Sales and Commission Splitting)
Sorry for delay in responding - been out of the office for a few days.
try adding
quit.
after the output close statement.
Troy Funte wrote:
> Thanks William. I'm off to a ... start, kind of.
> Using the code below, I got the export to work while using the Procedure Editor and F2 to run it. I'm having trouble getting it to run from an icon. When I run it from a .vtg icon (see Edit below), it will do the export first, then prompt me for a userID and Password. Then it finishes with the Procedure Editor screen. How can I get this to run "silently" without any need for additional intervention or screens?
> /* begin export program */
> output to c:\vntgwork\table.csv.
> for each PORel no-lock:
> export delimiter "," PONum POLine PORelNum ReceivedQty.
> end.
> output close.
> /* end of export */
> I found a way to run the procedure from a .vtg icon using the following.
> [Vantage Startup]
> Executable=E:\epic50\progress\bin\prowin32.exe
> Database=E:\epic50\Vantage\db\vantage
> IniFile=E:\epic50\Vantage\vantage.ini
> ParameterFile=E:\epic50\Vantage\db\Vantage.pf
> ConnectOptions=-N TCP -H localhost -S epic50
> TempDirectory=C:\vntgwork
> StartupProcedure=export.p
> OtherParameters=-rand 2 -q -basekey ini
> Troy Funte
> Liberty Electronics
> From: william
> Sent: Thursday, November 22, 2001 12:05 AM
> in its simplest form the following exports a table in comma separated
> format (.csv) that excel, and most other spread sheets, can handle
> easily.
> output to c:\vntgwrk\table.csv.
> for each table no-lock:
> export table delimiter ",".
> end.
> output close.
> /* end of export */
> You, of course, would replace c:\vntgwrk\table.d with the appropriate
> path and table name. A file of name table.d is created in c:\vntgwrk
> which you can then open with excel.
> You can also add a "where" clause to select a subset of records, and
> "by" specifications to determine the sort order. If you only want some
> fields dumped, replace "table" in the example (which would dump all
> fields in the database field order) with a list of field names (field1
> field2 ....) to get only the fields you want in the sequence that you
> want. Note that character fields will be enclosed in double quotes
> (excel expects this), and fields with an unknown value will be dumped as
> ? which excel treats as a character field.
> If you really need to get fancy, excel has a coma object interface and
> you can open and populate a spread sheet from within a Progress Program,
> without creating the intermediate file.
> HTH.
> Troy Funte wrote:
> > Todd mentions something I have been curious about. How easy is it to write 4GL programs to export tables/fields from Vantage to DBF or .xls files? Is there some sample code available that could be modified by a non-4GL programmer in a .p format (I don't have the 4GL source to compile). Also, is this something that can be run from a batch file nightly or via some auto-scheduler?
> > (Currently I do nightly exports using Vantage Export Utility along with "Ground Control", a macro writing program that basically does the keystrokes for you. This is cumbersome at best, and some time unreliable if Vantage is running slow for some reason. I'd like a better, more reliable way - perhaps with some more programming features.)
> > Thanks.
> > Troy Funte
> > Liberty Electronics
> > From: Todd Anderson
> > To: 'vantage@yahoogroups.com'
> > Sent: Wednesday, November 21, 2001 11:21 AM
> > Subject: RE: [Vantage] Sales and Commission Splitting
> > Todd,
> > Another way to go at this would be to write a few Progress reports that
> > export to a file. ( put "+" signs between fields - or some other odd duck
> > character )
> > Then import the data into MS-Access as "+" delimited fields.
> > >From there you can pretty much do whatever you want.
> > Todd Anderson
> > -----Original Message-----
> > From: Todd Caughey [mailto:caugheyt@...]
> > Sent: Wednesday, November 21, 2001 9:33 AM
> > Subject: [Vantage] Sales and Commission Splitting
> > I need some advice for the best way to approach a really thorny issue for
> > us. We need to determine "sales by rep" and "sales by the state where the
> > rep is located" in situations where there are multiple reps. Usually two
> > but sometimes three. Because of the way rep splits are handled in Vantage,
> > via an array within the invoice detail, it is not possible to sort the split
> > sales $ by rep or state. All of the "info" is contained within the one
> > detail record. I have tried linking every which way and using multiple rep
> > tables aliases, etc... and it won't work. If there was a mechanism to pass
> > through all of the data and store it in a temporary file, sort it there and
> > then report on it it would be pretty easy. In my COBOL days this was very a
> > piece of cake.
> > I am thinking of trying a Crystal subreport but have never used subreports.
> > Before I invest in the time to learn how I wanted to see if this appraoch
> > would even work for what I am trying to do. The company President has given
> > me a deadline to get split sales reports working by mid-December so I would
> > like to not take any more false routes.
> > The situation is that we might have a customer in Ohio with a plant in
> > Missouri. Our sales rep for Ohio and the rep for Missouri split the
> > commissions (and thus credit for the sales $) 50/50. The invoice detail for
> > a sale has the split info burried within in it so if I try to sort on rep or
> > state the same invoice detail record can't be in two places in the same
> > report. What I need is for the report to show 50% of the sales $ under one
> > state or rep and the other 50% under the other state/rep. I can easily
> > write a RB report to split the sales and commissions by each invoice and
> > even show the state and rep code for each split. But taking this and
> > re-sorting it is the problem.
> > So Yea or Nea... is Crystal subreports the way to handle hit? Or have RB
> > create a CSV files and use Crystal or Excel to re-sort it? Are Crystal
> > subreports hard to learn how to do? Any subreport "gotchas" waiting to
> > spring up and bite a newbie?
> > Thanks,
> > -Todd Caughey
> > Harvey Vogel Mfg. Co.
> > Yahoo! Groups Sponsor
> > <http://rd.yahoo.com/M=212180.1701098.3252983.1269402/D=egroupweb/S=17050071
> > 83:HM/A=812075/R=0/*http://www.verisign.com/cgi-bin/go.cgi?a=b17834980005700
> > 0>
> > <http://us.adserver.yahoo.com/l?M=212180.1701098.3252983.1269402/D=egroupmai
> > l/S=1705007183:HM/A=812075/rand=923152006>
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
> > already linked your email address to a yahoo id to enable access. )
> > (1) To access the Files Section of our Yahoo!Group for Report Builder and
> > Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.
> > <http://groups.yahoo.com/group/vantage/files/.>
> > http://groups.yahoo.com/group/vantage/messages
> > <http://groups.yahoo.com/group/vantage/messages>
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/links
> > <http://groups.yahoo.com/group/vantage/links>
> > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
> > <http://docs.yahoo.com/info/terms/> .
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have already linked your email address to a yahoo id to enable access. )
> > (1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.
> > (2) To search through old msg's goto: http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/links
> > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
> > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
> Specialists in Progress Databases and Software since 1986
> William E. Colls william@...
> PROComputer Systems Tel 613 591 0079
> 67 Willow Glen Dr. Fax 613 591 3924
> Kanata Ontario Canada www.procomsys.com
> K2M 1T1
K2M 1T1
