Progress procedure to run Report Builder
I want to thank Todd, Lonnie and Jim for their help since the problem
was with the syntax. I also had to change the record selection
for "LaborDtl.ActiveTrans = No" to "LaborDtl.ActiveTrans = False" in
order for it to work properly.
Brent O'Donnell
I am having a problem with the filter statement in the Progress
procedure that runs Report Builder.
I have successfully used this procedure before to run reports that
have a simple filter statement. The filter statement I am using now
is as follows:
strRBFilter = "LaborDtl.Company = 'VTAERO' AND (LaborDtl.PayrollDate
>= " + STRING(Date2_rb) + " AND LaborDtl.PayrollDate <= "+ STRING
(Date1_rb) + ") AND LaborDtl.ActiveTrans = 'No' AND LaborDtl.JCDept
= '2'or'3'or'4'or'5'or'8'or'11'or'12'or'15'or'16'".
The error I am getting now is " RB Filter contains an error at Offset
136: Invalid operation". I have tried removing what appears to be
the problem statement only to get the error at a different offset.
I was told the offset refers to the character position in the string
with the numbering starting with the the first character after the
opening ". Is this correct and can anyone tell me what could be
wrong with my syntax?
Any help would be appreciated.
Brent O'Donnell
Can't vouch for the syntax of the Progress procedure part but when RB barfs
on a calculated field due to "Invalid Operation" I almost always find that
it is due to lack of a space between things. In this case I would be really
suspicious about the '2'or'3'or'4' where I would try a space between the
single-quotes and the or's. Also between the " and the + near the end of
the second line. Just a guess.
-Todd C.
Sent: Friday, October 18, 2002 6:36 AM
Subject: [Vantage] Progress procedure to run Report Builder
is as follows:
Brent O'Donnell
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://rd.yahoo.com/M=237459.2482214.3895589.2146399/D=egroupweb/S=17050071
83:HM/A=1278097/R=0/*http://www.verisign.com/cgi-bin/go.cgi?a=b3087010792600
4000>
<http://us.adserver.yahoo.com/l?M=237459.2482214.3895589.2146399/D=egroupmai
l/S=:HM/A=1278097/rand=840953398>
I see 2 possibilities immediately. ... "+ string(date1 ... I would
place a space between double quote and the +. Have to be perfect
with spacing.
I think Todd is also right about ... Labordtl.JCDept
= '2'or'3'or... That's not correct. I would use a lookup or index
function, or possibly.. labordtl.jcdept = '2' or labordtl.jcdept
= '3' or ..
Then test strRBFilter. First, build the filter in RB, print it on a
report, and compare it to strRBFilter's contents in a message
statement or output to a file.
-Lonnie
Offset
string
> Brent O'Donnell
Brent,
Remove the quotes from LaborDtl.ActiveTrans = 'No'. The field is a logical
not string.
Jim Stetter
Sent: Friday, October 18, 2002 7:36 AM
is as follows:
Brent O'Donnell
ADVERTISEMENT
