Yes, Troy - you are of course absolutely right! I don't know how the extra backslashes got in there, but here it is in the correct form:
REGEDIT4
[HKEY_LOCAL_MACHINE\Software\PSC\PROGRESS\9.1C\Startup]
"PROMSGS"="v:\progress\\promsgs"
"DLC"="v:\progress"
Simply create a blank notepad document, copy the above text into it, then save it as "Promsgs_error_fix_Pro9.1C.reg" somewhere on the network. Then import it into each client - easy!
Again, this works for Progress 9.1c, and you should substitute the drive letter "V" for whichever drive letter is mapped to your Vantage server.
++ Andy Watts
++ Ripley Engineering Ltd
++ Tel: 01256-473940
++ Fax: 01256-479991
++ mailto: andy@...
REGEDIT4
"DLC"="v:\progress"
++ Andy Watts
++ mailto: andy@...
