I just confirmed in our test system that if a PO is generated for a
purchase direct requirement for LESS THEN the requirement, when PO
Suggestions are generated again a suggestion will be created for the
entire job requirement. This will result in ordering more than
required. If you order more than the required amount, there is no ill
effect.
8.03.404A
Has anyone else encountered this issue?
It came about when the quantity for the job was increased and thus
generated a suggestion for the total required amount without considering
what has all ready been ordered.
Regards,
Andrew Best
effect.
8.03.404A
Regards,
Andrew Best
