It has to be. I would guess the logic is based on receiving to a bin and since technically there is nothing on hand until the inspection is cleared there is nothing to trigger the initial PO Line logic.
Â
I would guess if you test without inspection set for the supplier or part class and tried it would work but we;ll see
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Sent: Tuesday, September 25, 2012 4:01 PM
Subject: Re: [Vantage] Purchase Kanban - What Triggers the PO Release
Â
Hmmm. No joy Mark.
Â
Just occurred to me though that our parts are inspection required & I wonder if this interrupts the process triggers somehow (particularly on that initial receipt... Having them in the pending inspection queue may be our issue).
Â
Appreciate it though (and not done with it yet).
Â
Rob BrownÂ
To: "mailto:vantage%40yahoogroups.com" <mailto:vantage%40yahoogroups.com>
Sent: Tuesday, September 25, 2012 11:00 AM
Â
Rob, I just posted a word document on the Vantage Files which gives you the procedure for Kanban. Screenshots are in E9 but should work the same in Vantage
Â
I tried it and it worked so let me know if it works for you
From: Robert Brown <mailto:robertb_versa%40yahoo.com>
Sent: Sunday, September 23, 2012 10:53 AM
Â
I seem to recall you have to do a receipt (when below Min) to bring it above min - & then when it again drops below min it automagically splits of a new release in the way you have defined. (That's 'priming the process' as described to me by people in and out of epicor fairly consistently over the years).
Â
Hope you get it working Mark (& share).
Â
Rob
Sent: Saturday, September 22, 2012 12:43 PM
Â
I have as well. I set it up about 4 years ago at another company and we ended up not using it and am now just trying it again. I created the PO line and added two releases, which showed up on the kanban monitor along with the supplier requests. About the only thing I think it will do is update the PO release date, not sure. Otherwise, it just appears informational as to what PO lines are open
Â
I'll be doing more testing this week, will let you know what I find
Sent: Saturday, September 22, 2012 11:48 AM
Â
I've been trying to get this to work for 4 yrs to no avail (whse and bin purch kanbans). On 8.403.9xx, bin kanban set up refuses to acccept the linked PO line. Whse appears to allow set up - but trigger conditions trigger no split of ne release.
Â
There is a very specific 'prime the pump' series of steps/conditions documented to get it working - but it has never worked for us.
Â
I have applications for this across our business so if you make any headway, I'd apprecciate a share.
Â
Rob Brown
To: Vantage User Group <mailto:vantage%40yahoogroups.com>
Sent: Friday, September 21, 2012 12:48 PM
Subject: [Vantage] Purchase Kanban - What Triggers the PO Release
Â
We have setup a part warehouse (not at the bin level) as a purchase kanban with a PO and Line. The parts shows below onhand in the Kanban monitor but no PO release or supplier requests are showing up. What triggers the PO release to update?
Â
Â
Hmmm. No joy Mark.
Â
Â
Â
Rob BrownÂ
Â
Â
Â
Â
Â
Rob
Â
Â
Â
Â
Â
Â
Rob Brown
Â
