Purchase Order Entry - Hide Mass Print option
Good morning,
I am doing a customisation of the purchase order screen that will only allow non-stock purchase orders to be raised.
I also want to stop the end user from being able to do a Mass Print but not sure how to hide this option from the Actions menu
You may find it easier to lock down the process id rather than modifying the screen.
PO Mass Print Process ID: PR000357 using it’s own menu security id: SECPR0208 - You can either make this security manager only or create a group and assign the selective few.
Make sure you update the menu security id to use your group and disallow everything else.
That has worked for me, thank you :slight_smile:
Please mark the solution as solved… Thanks
