We are using QA for DMR (vendor supplied material) and RMA (Customer
Returns) and set up our reson codes with DMR, RMA, INSP prefixes to
separate the funtions. There are some overlaps. Here are our codes
Keep in mind we're on 4.0
Description ReasonCode ReasonType
RMA - DAMAGED IN SHIPMENT DAMSH A
RMA - MATERIAL DEFECT MATDE A
RMA - WRONG MATERIAL MATWR A
RMA - NOT TO DRAWING SPECS NOTSP A
RMA - OTHER REASONS (Misc.) OTHER A
SHIPPED TOO MANY SHIP2 A
DMR - Damaged in Shipment DMR01 D
DMR - Out of Specifications DMR02 D
DMR - Flaw in Material DMR03 D
DMR - Paperwork Problems DMR04 D
DMR - Overstock Material DMR05 D
DMR - MATERIAL REPLACEMENT DMR06 D
INS - Workmanship INS01 D
INS - Material Defect INS02 D
INS - Instructions/Drawing INS03 D
INS - Machinery INS04 D
INS - Handling INS05 D
INS - Other INS06 D
02-PG Cost of Sales COS02 M
04-PG Cost of Sales COS04 M
10-PG Cost of Sales COS10 M
12-PG Cost of Sales COS12 M
16-PG Cost of Sales COS16 M
17-PG Cost of Sales COS17 M
18-PG Cost of Sales COS18 M
23-PG Cost of Sales COS23 M
25-PG Cost of Sales COS25 M
Adjust-Cost Correction COST M
Adjust-Cracked or Damaged CRACK M
DMR - Flaw in Material DMR-1 M
zz-INITIAL START OF SYSTEM INITL M
Job/Part Missed End of Month INVEM M
Adjust - Production Overrun OVER M
zz-INCORRECT PART NUMBER PART M
Adjust-Physical Count PHYS M
Adjust-Purchase Receipt POADJ M
RMA-MATERIAL RETURN RETRN M
RMA-Returned Material Scrapped RMA01 M
Adjust-Scrap Quantity onHand SCRAP M
Adjust-Shipped Parts Incorrect SHIP M
Adjust-Job Costing Valuation VALUE M
Adjust-Write Off Inv. Costs WRITE M
ENGINEERING ENG R
INSTRUCTIONS INCORRECT INSTR R
MATERIAL MATL R
OTHER REASONS OTHER R
WORKMANSHIP WORK R
ENGINEERING ENG S
INSTRUCTIONS INCORRECT INSTR S
MATERIAL MATL S
OTHER REASONS OTHER S
WORKMANSHIP WORK S
IS Manager
Weaver Industries, Inc.
717 336 7507 phone
717 336 4182 fax
rdover@...
www.weaverind.com
INS - Other INS06 D
ENGINEERING ENG R
MATERIAL MATL R
WORKMANSHIP WORK R
ENGINEERING ENG S
MATERIAL MATL S
WORKMANSHIP WORK S
> Version: 5.20.313Russ Dover
> I was wondering if anyone else is using the QA module and handling
> RMA processing. I currently have a call in to support but they need
> to research it a bit more so I thought I'd see if anywhere else was
> having an issue similar to ours.
> I have setup reason codes in the reason code maintenance under the QA
> module. There are several pre-defined types (not change or addable)
> and under the RMA type I ahve added 9 specific reason codes.
> Basically why did the customer send the stuff back to us. When we go
> to disposition the RMA (usually scrap so we select "Fail") there is a
> reason field on the screen but it does not refer to the RMA reason
> codes. It only has <add>. This goes to the Reason Code maintenance
> screen but has no association to the type "RMA". Also, curiously, in
> the help screen for RMA Disposition there is no mention at all (in
> the green hyperlinks) for the Reason field.
> Either we are doing something wrong or there are some chunks of RMA
> processing that are not correct. Just wondering if this is a known
> issue.
> Thanks,
> -Todd Caughey
> -Harvey Vogel Mfg. Co.
IS Manager
717 336 7507 phone
717 336 4182 fax
rdover@...
www.weaverind.com
