Greg thanks for the example. I think I can use the same concept for what I am trying to do.
Steve
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Greg Payne
Sent: Tuesday, September 10, 2013 11:20 PM
Subject: RE: [Vantage] Quote cost
If you are referring to the Unit cost on material, then I have this abl code in a Data Directive that does that.
Greg
The condition is
the QuoteMtl.RowMod field of the changed row is equal to the 'A' expression
The action is abl code.
/* SET Cost from Part Cost*/
For each ttQuoteMtl FIELDS(Company PartNum EstUnitCost) where ttQuotemtl.EstUnitCost = 0 no-lock,
each PartCost FIELDS(Company PartNum StdMaterialCost) where
PartCost.Company = ttQuoteMtl.Company and
PartCost.Partnum = ttQuoteMtl.Partnum no-lock.
Assign ttQuoteMtl.EstUnitCost = PartCost.StdMaterialCost.
End.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Steve
Sent: Tuesday, September 10, 2013 1:58 PM
To: 'Vantage'
Subject: [Vantage] Quote cost
Has anyone automatically populated the unit price in the quote module with cost that is setup in the part master or something similar?
Steve
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6280 and immediately delete the communication.
