Hi there
I am making a new customization based on an already customized Quote Entry form. When I copy one groupbox and the controls it contains to a new groupbox and then try to remove some of the controls from the copied box all seems good. However after saving the changes to a new customization / exitting and going back in the deleted controls are still there. Why is this?
Also I’ve noticed a send to back / bring to front option - could this be linked?
Andre
The “Copy and Paste” for customization is not fool-proof. You may have to either:
- Use code to change the parent of the group box
- Create the controls manually
- After copying, remove the tab stop, move it outside the boundaries of the group box and make Visible = false.
Thanks Jason - sounds as if it might be a better option just to create from scratch the new stuff.
Depending on the number of controls, yes. I personally never use that as I find later that it causes other issues I can’t control.
OK thanks for the advice - I’m new to Epicor
