It was the best way for my guys to "see" who were customers and who were
prospects.
Because what they look at are the search screens filtered on all. Trust
me, I've been down this road too many times to explain it over and over
again.
M. Manasa Reddy
manasa@... <mailto:manasa@...>
800.852.2325
630.806.2000 ofc
630.806.2001 fax
www.weldcoa.com
Of Virginia
Sent: Friday, December 03, 2010 4:08 PM
Subject: [Vantage] Re: Quote Entry No Customer Number
Hi Manasa; Out of curiosity, if you have CRM and can use the suspect,
prospect & customer status to track which company records are actual
customers (have placed orders) vs. prospects (requested a quote) vs.
suspect (neither placed an order nor an RFQ), what business purpose does
it serve to assign an alpha ID and then change it to a numberic ID when
they place an order?
Virginia Joseph
Deep Hole Specialists, LLC
"Manasa Reddy" <manasa@...> wrote:
Behalf
prospects.
again.
M. Manasa Reddy
800.852.2325
630.806.2000 ofc
630.806.2001 fax
www.weldcoa.com
Of Virginia
Virginia Joseph
>quote,
> If you have CRM, what we do is enter the customer with an ALPHA ID.
> This makes the "Customer" an actual "SUSPECT" in the system. When we
> create the Quote, the system makes the "SUSPECT" a "PROSPECT" (but we
> leave the ID as an ALPHA id).
> If the "PROSPECT" gives us a PO, then we create an order from the
> which makes the "PROPECT" to an actual "CUSTOMER" in the system. At[mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> this point we change the ALPHA id into a numeric id. Of course in the
> middle of all of this we are checking out their references. But we
> won't change the ID to numeric until they actually provide a real PO.
> Remember, the idea of the suspect, prospect, and customer designations
> only come about if you own CRM.
> Hope this helps.
> Manasa
> M. Manasa Reddy
> 800.852.2325
> 630.806.2000 ofc
> 630.806.2001 fax
> www.weldcoa.com
Behalf
> Of Gary Wojtowiczguarantee
> Sent: Friday, December 03, 2010 9:09 AM
> Subject: [Vantage] Quote Entry No Customer Number
> We need to make a quote for a potential customer, there is no
> that they will become a customer. Vista will not let you make a quotewould
> unless you have a customer number, so that means you have to set up a
> customer number for a company with all the info for that company. In
> classic all you had to do was skip the customer number and type in the
> company name, address, contact to make a potential quote. If they
> accepted you quote then you went an made them into a customer. We
> like to know what everyone is doing for this situation.[Non-text portions of this message have been removed]
> Gary Wojtowicz
> AJR Industries, Inc.
