Based on what it says in the help file this flag gets set based on the part even before jobs are created.
So no use to me.
I will do it the long way with joins.
Ephraim Feldman
Date: Mon, 17 May 2010 12:34:32
To: <vantage@yahoogroups.com>
Subject: RE: [Vantage] Quote to Order - Order to Job
I'm guessing it gets set when you check "make direct" on a release, or if you create a job with a demand link to a sales order release.
-bws
Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix / Picometrix
���� bspolarich@... ~ 734-864-5618 ~ www.advancedphotonix.com
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of effgroups@...
Sent: Monday, May 17, 2010 12:27 PM
Subject: Re: [Vantage] Quote to Order - Order to Job
Thanks brian
Will this flag be set after creating the job from order or is it a flag that this order is available to turn into a job?
Ephraim Feldman
Date: Mon, 17 May 2010 10:20:40
If OrderRel.Make = True then the release is linked to a job:
D: Indicates if this requirement or any part of it will be manufactured. Default the setting to "No" if valid Part and the Part.Type is "S" or "P". Default the setting to "Yes" if the part is not found in Part master or the Part.Type = "J". This flag also gets set if this release gets linked to a Job via Job Entry. There is an Index on this field so that we can display releases that need have a job assigned to them. This display is part of Job Entry.
I don't think Vantage has a Part Type of 'J' anymore so this may be a holdover from 6.x or previous versions?
-bws
Sent: Monday, May 17, 2010 7:55 AM
Thanks all,
I knew about the jobprod table. My question was if there is some type of flag that the order is connected to a job (like the ordered flag in quotedtl) but I guess I have to join the tables and to avoid duplicates I can make a find first jobprod.
Ephraim
Ephraim Feldman
Date: Fri, 14 May 2010 14:01:04
To: vantage@yahoogroups.com<vantage@yahoogroups.com>
This is the key (what Sean estates): JobProd table
If you only need to know if any Order has been linked to a Job, just link your OrderHed table to JobProd (through Company and OrderNum and Outter-Joint) and evaluate at JobNum in JobProd table; just be aware that this can print duplicates because there might be multiple jobs for the same Order because the relationship between a Job and an Order happens at OrderRel (Order Release).
Regards.
Roel Martinez
ERP Analyst
SABRE TUBULAR STRUCTURES (tm)
www.sabretubularstructures.com<http://www.sabretubularstructures.com/>
8653 E. Hwy 67 | Alvarado, TX 76009
Phone: 817-852-1700 ext. 11858 | Direct Line: 817-852-1858 |Fax: 817-852-1705
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Sean McDaniel
Sent: Friday, May 14, 2010 1:29 PM
Probably the jobprod table as it contains the order information for make to order jobs.
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of efyf_1999
Sent: Friday, May 14, 2010 2:07 PM
Subject: [Vantage] Quote to Order - Order to Job
Hi All
I am trying to get a report of all Quotes turned into orders but not yet turned into a job .
I know that on the Quotedtl there is a field ordered that is a flag if it was ordered and if i want to find the order i have to join to orderddtl that has the quotenum and quoteline.
My question is do i have to join the Jobtable to find if it has been turned into a job or is there a flag to indicate that the order has a job attached.
Any ideas on how to approach this report would be welcome
Have a nice weekend group.
Ephraim
So no use to me.
Ephraim Feldman
-bws
Thanks brian
Ephraim Feldman
-bws
Thanks all,
Ephraim
Ephraim Feldman
Regards.
Roel Martinez
ERP Analyst
Hi All
Ephraim
