The Intel PCIe is designed to be software raided. Each 200gb has a separate Enterprise grade controller, the drives have 7 petabytes of endurance for 400 gb model of full write @8k. We take a snapshot of the database each hour backed up to the SAN.
Eventually we will build a SSD SAN with 10 gig connection for the database, unfortunately having one dedicated server, there is automatic failover like we have with our other virtualized servers on the SAN.
--- In vantage@yahoogroups.com, Ned <TechnoBabbly@...> wrote:
> Are you actually running hardware RAID with a PCIe drive? Is it even
> possible to run hardware raid on PCIe drives?
> This is my one major apprehension in the recommendation of PCIe drives for a
> customer installation, lack of simple redundancy.
> -----Original Message-----
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> just_check
> Sent: Wednesday, July 11, 2012 8:57 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: RAID 1 / RAID 10
> We have a found the best performance from Intels new PCIe SSD 910. The 400gb
> comes with two 200gb modules and the 800gb comes with four 200gb modules,
> there is no speed improvment with stripe RAIDing them, so we have them
> mirrored.
> http://thessdreview.com/our-reviews/intel-910-pcie-ssd-review-amazing-perfor
> mance-results-in-both-400gb-and-800gb-configurations/
> --- In vantage@yahoogroups.com, John Driggers <waffqle@> wrote:
> > Also, newer SSDs carry more storage than they are rated for. I.E. a
> > 200GB drive has 250GB of storage on it. As cells go bad the drive will
> > stop using them and replace them with a 'spare' cell. Combine this
> > with write-leveling and TRIM support in modern operating systems and
> > you should see MUCH longer life.
> > Also, make sure you disable the defrag and such that is auto enabled
> > in modern versions of Windows.
> > Also, for what it's worth we've seen no difference in drive life
> > between the enterprise and the consumer level drives. As Jose
> > mentioned, we've been running our Epicor on an SSD RAID10 for 2 years with
> no failed drives.
> > We're using regular old OCZ drives. You can get good 250gb drives for
> > just under a dollar a GB anymore which is pretty comparable to what
> > you'd pay for modern SAS drives anyway.
> > *John Driggers*
> > *Chief Data Wrangler*
> > *I have an Epicor blog <http://usdoingstuff.com/>. How useful is
> > that?*
> > *:: 904.404.9233
> > :: waffqle@
> > :: http://www.usdoingstuff.com <http://www.usdoingstuff.com/>
> > On Tue, Jul 10, 2012 at 3:44 PM, Jose Gomez <jose@> wrote:
> > > We use webbased interface but google supports the exchange protocol,
> > > so technically nothing has to change. Though the web interface is a
> > > thousand times better.
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > *T: 904.469.1524 mobile
> > > E: jose@
> > > http://www.josecgomez.com
> > > <http://www.linkedin.com/in/josecgomez> <
> > > http://www.facebook.com/josegomez>
> > > <http://www.google.com/profiles/jose.gomez> <
> > > http://www.twitter.com/joc85>
> > > <http://www.josecgomez.com/professional-resume/>
> > > <http://www.josecgomez.com/feed/>
> > > <http://www.usdoingstuff.com>
> > > *Quis custodiet ipsos custodes?*
> > > On Tue, Jul 10, 2012 at 3:38 PM, Rob Bucek <rbucek@> wrote:
> > > > Go 64 bit, obviously you can utilize much more ram that way..and
> > > > unless you spent all your money on those ssd's... get at least
> > > > 32gb or more of
> > > ram
> > > > as cheap as it is comparably you won't be sorry.
> > > > Rob Bucek
> > > > Production Control Manager
> > > > PH: (715) 284-5376 ext 311
> > > > Mobile: (715)896-0590
> > > > FAX: (715)284-4084
> > > > [Description: cid:1.234354861@]< http://www.dsmfg.com/> (Click
> > > > the logo to view our site)<http://www.dsmfg.com/>
> > > > Behalf Of Vic Drecchio
> > > > Sent: Tuesday, July 10, 2012 1:39 PM
> > > > To: Vantage Yahoo
> > > > Subject: [Vantage] RAID 1 / RAID 10
> > > > I'm doing some shopping for new servers. I need a new Email server
> > > > now
> > > and,
> > > > very shortly, a new Epicor server.
> > > > I'm far from an expert on hardware, but I've done my research and
> > > > I
> > > wanted
> > > > to bounce it off the group. I'm anxious to hear your thoughts.
> > > > For both of my severs (Email and ERP), I'm considering SSD's. I
> > > > think the technology is mature enough to start considering and
> > > > relying upon SSD's (thoughts?). Does anyone have any success or
> > > > horror stories to share? To me, a solid-state-device is inherently
> > > > less prone to crashes because
> > > there
> > > > are no moving parts. But they are more expensive than hard drives,
> > > > so
> > > that
> > > > may be a concern.
> > > > I know RAID 10 is basically two sets of RAID 1 models. I like the
> > > mirroring
> > > > aspect and hard drives are cheap enough now to warrant the "waste
> > > > of
> > > space"
> > > > in a RAID 1 configuration.
> > > > I'm thinking RAID 1 will be sufficient for email but I'm wondering
> > > > if I should go RAID 10 on the ERP server because I've read that
> > > > its I/O is slightly faster.
> > > > I want absolute redundancy and will also get dual power supplies.
> > > > RAM is an easy choice, nothing less than 16GB.
> > > > What also about OS? Windows Server 2008 is completely compatible
> > > > with Vantage 8.03.xxx, right? (yes, once I get the hardware in
> > > > place, we will
> > > be
> > > > upgrading to E9.) :-)
> > > > Any other thoughts?
> > > > TIA for your input!
> > > > Vic
> > > > Vic Drecchio
> > > > Director of IT
> > > > Swepco Tube, LLC - Clifton, NJ
> > > > Ext: 1379
> > > > Office: 973.272.1379
> > > > Mobile: 704.530.3092
> > > > No virus found in this message.
> > > > Checked by AVG - www.avg.com
> > > > Version: 2012.0.2195 / Virus Database: 2437/5123 - Release Date:
> > > > 07/10/12
> > > > [Non-text portions of this message have been removed]
> > > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
> > > must have already linked your email address to a yahoo id to enable
> > > access. )
> > > (1) To access the Files Section of our Yahoo!Group for Report
> > > Builder and Crystal Reports and other 'goodies', please goto:
> > > http://groups.yahoo.com/group/vantage/files/.
> > > (2) To search through old msg's goto:
> > > http://groups.yahoo.com/group/vantage/messages
> > > (3) To view links to Vendors that provide Vantage services goto:
> > > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
