Thanks for clearing that up, Jim. I did have the true and false statements
in the wrong order.
Ted Kitch
Sent: Thursday, August 10, 2000 12:38 PM
To: vantage@egroups.com
Subject: RE: [Vantage] RB IF statement
I hate to nitpick, but the correct formula would be:
IIF (TotlMiscChrg <= 20, 0, TotalMiscChrg) notice the less than or equal
sign instead of greater than
or
IIF (TotlMiscChrg > 20, TotalMiscChrg,0) notice the "true" condition
yields the actual charge
The statements as originally supplied would result in just the opposite of
that intended!
Regards
Jim Stetter
Sent: Thursday, August 10, 2000 1:10 PM
To: 'vantage@egroups.com'
It is only displaying 0's and 1's, because that is what your formula is
telling it to do. If you only want to show the field TotlMiscChrg that is
over $20 then change your formula to the following:
IIF (TotlMiscChrg > 20, 0, TotalMiscChrg)
That should take care of the problem.
Hope this helps.
Ted Kitch
Sent: Thursday, August 10, 2000 12:06 PM
To: Vantage egroups list
Subject: [Vantage] RB IF statement
Okay all of you RB gurus; I have another statement question. I want to
display my Freight cost only if it is greater than $20. It seems to only be
displaying 0's and 1's. I would like it to display the cost ONLY IF it is
greater than $20.
IF(TotlMiscChrg > 20, 0,1)
Thanks Again!
Wendy Pursche
Network Administrator
Schmald Tool & Die, Inc.
(810) 743-1600 ext.323
wpursche@...
_____
<http://click.egroups.com/1/8117/13/_/411782/_/965928372/>
_____
<http://www.egroups.com/files/vantage/>
in the wrong order.
Ted Kitch
or
that intended!
Regards
Jim Stetter
Hope this helps.
Ted Kitch
greater than $20.
Thanks Again!
Wendy Pursche
wpursche@...
_____
_____
