Re-install Vantage on new harddrive problem
Thank you for your input, Andy.
I'll double check the Netware option.
We want to upgrade all our MIS department but our parent company/owner said
as long as our computers are working he will not give us any $ to spend. We
figure the equipment in his equipment is quite more up-to-date than ours.
But we are such a small company and he has us so dependent on his own
business we're between a rock and a hard place.
Thanks again,
Monica
>Hi Monica,
>I used to have lots of trouble with error message quite similar to the one
you're experiencing. Did you load a Netware client on the Windows 95 machine
by any chance? If so, I found that more often than not, Vantage client would
refuse to install AFTER the Netware client was installed, but installs quite
happily BEFORE.
>I had to wipe the HD of a machine that played this trick, and re-install
Windows from scratch, ensuring that Vantage went on before the Netware client.
>Other than that, it's a mystery - we don't use Win95 on any Vantage client
PC's, not sure why anyone would still be using it to be honest - it's almost
10 years old now!!
>HTH,
>Andy
>>> We are still on Vantage 4.
>>> We had a hard drive go out on a pc, so I had to install a new one. We are
>>> still on Windows 95, so I installed Win95, the Year2000 update and the
>>> Office software just fine. It connects to the network, maps to Vantage and
>>> access its files. But when I try to install the VantageClientSetup, after
>>> selecting the progress and vantage paths and click install the progress
>>> software it errors out telling me:
>>> Warning: DialogShowSharedInstall: DLL(util.dll) NOT loaded.
>>> Click OK
>>> Severe: Preamble: Internal dialog box error.
>>> Does nothing everytime I click OK
>>> The only way to get out of it is to:
>>> Ctl-Alt-Delete End Task VantageClientSetup
>>> Ctl-Alt-Delete End Task Severe error
>>> The only util.dll is in the Epicor/progress folder.
>>> If anyone knows what I can try, I would really appreciate it. I've been
>>> trying to figure this out for 2 days now.
>>> Thank you,
>>> Monica Greybar
>Andy Watts
>Ripley Engineering Ltd
>Tel: 01256-473940
>Fax: 01256-479991
>www.ripley-eng.co.uk
>Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
>(1) To access the Files Section of our Yahoo!Group for Report Builder and
>(2) To search through old msg's goto:
>(3) To view links to Vendors that provide Vantage services goto:
>Yahoo! Groups Links
Click OK
Thank you,
Monica Greybar
Hi Monica,
I used to have lots of trouble with error message quite similar to the one you're experiencing. Did you load a Netware client on the Windows 95 machine by any chance? If so, I found that more often than not, Vantage client would refuse to install AFTER the Netware client was installed, but installs quite happily BEFORE.
I had to wipe the HD of a machine that played this trick, and re-install Windows from scratch, ensuring that Vantage went on before the Netware client.
Other than that, it's a mystery - we don't use Win95 on any Vantage client PC's, not sure why anyone would still be using it to be honest - it's almost 10 years old now!!
HTH,
Andy
>> Click OK
>> Thank you,
>> Monica Greybar
Andy Watts
Tel: 01256-473940
Fax: 01256-479991
