using (StreamReader reader = new StreamReader(Path.Combine(filePath, FileName)))
var filePath = new FilePath(ServerFolder.CompanyData, "SubFolder", "FileName.txt");
using (var streamReader = this.Sandbox.IO.File.OpenText(filePath))
string line = streamReader.ReadLine();
this.output = $"First line: {line}";
Key Fixes
FilePath is used instead of raw string paths.
this.Sandbox.IO.File.OpenText(filePath) is used instead of new StreamReader(...).
Example Folder Setup
You can only use ServerFolder.CompanyData or ServerFolder.UserData. So if your file is in \\EpicorServer\CompanyData\Folder_Name\myfile.txt, the correct path would be:
var filePath = new FilePath(ServerFolder.CompanyData, "Folder_Name", "myfile.txt");
SaaS
var folderPath = new FilePath(ServerFolder.CompanyData, "Folder_Name");
folderPath.Combine(this.FileName);
var filePath = folderPath;
I personally add sections like this to functions that use uploaded files.
// Rename the file to a unique name if it already exists
string uniqueFileName = Guid.NewGuid().ToString() + "_" + this.callContextClient.CurrentUserId + "_" + this.FileName;
var backupPath = new FilePath(ServerFolder.CompanyData, "Folder_Name");
backupPath.Combine(uniqueFileName);
if (this.Sandbox.IO.File.Exists(filePath))
this.Sandbox.IO.File.Move(filePath, backupPath, overwrite: true);
filePath = backupPath;
