Reboot of Vantage Server
John
I'm running Vantage 4.0. My database was crashing weekly. Sometimes
actually rebooting the Vantage server. On the advice from Virginia Johnson
at Epicor I applied the patch to get it to ver 90B44. It took less than ten
minutes to apply. I did it at lunchtime. This cured a memory leak. I also
made the promsgs in the Progress folder Read Only so more than one user
could attach to it at one time. Since then my database has been staying up
for 30 day stints.
As far as your users. You can use ProMon to chop their connections or just
shut down the database. The results at the client are the same. The user
gets three error messages and has to hit the space bar. Then they can
reattach. If your crashing all the time your users are probably well versed
at this. Make a company announcement when shutting down the DB tell them it
will be down for twenty minutes when you need ten because they are going to
start hitting it while it is coming up. I have 81 users including 9 data
collection stations in three building. If you have Citrix or Terminal Server
connections as I have from my farthest building make sure you kill all the
terminal server connections while you have the database down.
Good Luck
Cliff Drumeller
Information Technology Manager
Mass Precision Sheetmetal
408 954-0200 ex 217
Sent: Friday, April 25, 2003 1:04 PM
Subject: [Vantage] reboot of Vantage Server
Hi all,
We have been running into problems lately which are solved
by rebooting the server.
How often due you reboot?
How do you insure that everyone is out before the reboot?
John Mansfield
General Sheet Metal
Yahoo! Groups Sponsor
<http://us.adserver.yahoo.com/l?M=247865.3003379.4507215.2595810/D=egroupmai
l/S=:HM/A=1482387/rand=525784684>
Hi all,
John Mansfield
General Sheet Metal
What type of problems are you seeing?
I usually make an overhead page that I will be restarting the system in 2
minutes?
Then I shut down the database, If they haven't logged out and most don't it
just kicks them off.
Patrick
Sent: Friday, April 25, 2003 3:04 PM
Hi all,
John Mansfield
General Sheet Metal
I only re-boot when needed, very rarely, once a month, if that. When I need
to, I send out a message to all connected users that the server will be
re-booted at a certain time (usually break time or lunch time if it can
wait), and tell them all to disconnect before that time. Anyone note
disconnected, I disconnect through promon and then I reboot.
I am getting Dr Watson errors.
----- Original Message -----
Sent: Friday, April 25, 2003 3:10 PM
Subject: RE: [Vantage] reboot of Vantage Server
minutes?
Patrick
Hi all,
John Mansfield
General Sheet Metal
Lately I've only been rebooting when I install a new patch.
(about every 6 - 8 weeks). As others have stated, I check
promon and make a company wide announcement that the server
will be going down in x minutes. If users are not out, they
get killed when I shut the db down.
Sent: Friday, April 25, 2003 4:04 PM
Hi all,
John Mansfield
General Sheet Metal
Is there any risk of data loss by kicking them out?
minutes?
Patrick
Hi all,
John Mansfield
General Sheet Metal
The user may lose 1/2 a screen that's been filled out, but I never have seen
any database corruption.
Sent: Friday, April 25, 2003 3:25 PM
Subject: Re: [Vantage] reboot of Vantage Server
minutes?
it
Patrick
Hi all,
John Mansfield
General Sheet Metal
have
------------------------ Yahoo! Groups Sponsor ---------------------~--> Get
128 Bit SSL Encryption!
http://us.click.yahoo.com/xaxhjB/hdqFAA/bW3JAA/PhFolB/TM
What happens to the client connection? Does the screen close down and show a desktop?
Sent: Friday, April 25, 2003 3:27 PM
minutes?
it
Patrick
Hi all,
John Mansfield
General Sheet Metal
have
Clients receive an error message about being unable to reach the Vantage
server.
Lydia
Sent: Friday, April 25, 2003 1:30 PM
desktop?
seen
2
minutes?
it
Patrick
Hi all,
John Mansfield
General Sheet Metal
have
and
and
have
Either 1) a database connect pop up box, press ok, vantage disappears and
then you have to just restart, 2) pop up box after pop up box appears and
generally it's a good idea to reboot the PC. 3) Vantage disappears but gets
errors when restarting, then it's again the only choice but to reboot.
Patrick
Sent: Friday, April 25, 2003 3:30 PM
desktop?
seen
2
minutes?
it
Patrick
Hi all,
John Mansfield
General Sheet Metal
have
and
and
have
Promon will leave the Vantage screen up until the user tries to do
something, then they will receive 3 error messages and dump them into the
Procedure editor. There is a Kill all in Promon which works really well.
I trigger a timeout at the workstations which backs the user out and cleanly
closes Vantage at the workstation, then I use Promon to close and Data
Collection and Report builder sessions. Or I VNC into the workstation and
shut it down. All depends upon how much time you want to spend closing
users down.
As long as you have Crash Protection turned on, there shouldn't be any
problems with shutting down Vantage even while users are in Vantage.
Progress will back out the sessions before it closes the database.
desktop?
seen
2
minutes?
it
Patrick
Hi all,
John Mansfield
General Sheet Metal
have
and
and
have
How many office users and shop floor users do you have?
Patrick Winter
From: sarah.vareschi@... [mailto:sarah.vareschi@...]
Sent: Friday, April 25, 2003 3:15 PM
http://us.click.yahoo.com/W7NydA/hdqFAA/bW3JAA/PhFolB/TM
19 office, 11 DC
I have 11 office and 12 shop. The shop uses both Vantage and the VMM or data collection program.
Sent: Friday, April 25, 2003 3:16 PM
Patrick Winter
I use ProMon to monitor who is logged on to Vantage. As a matter of fact ProMon is always open on our server's desktop. When need to
shut down the server or the database I page twice on the intercom then I switch to option 8 in ProMon's main menu, which is
"Shutdown Database". This option gives me an ability to disconnect users one by one or emergency shutdown which will kick everyone
out. If there is no emergency I contact the person, he or she could on the phone taking orders. This way I find out if there are any
orphan client connections.
Mike Tonoyan / MIS Manager
All American Products Co.
1135 Aviation Place
San Fernando, CA 91340
USA
Tel.: 818-361-0059 Ext.: 246
Fax 818-898-2236
E-mail: miket@...
Web: www.allamericanproducts.com
To: <vantage@yahoogroups.com>
Sent: Friday, April 25, 2003 1:10 PM
> minutes?
> Patrick
> From: mansfield1024 [mailto:johnm@...]
> Hi all,
> Thanks,
> John Mansfield
> General Sheet Metal
enable access. )
I know of a Vantage server thatÂ’s been running non-stop since July 12, 2002.
Before that when it was me against the world, the server got shut down and
restarted every Monday morning at 5:30 before the rest of the world got
going for the week. Any sessions running got shutdown in Promon and the
error message on the user desktop served as a subtle reminder they left an
open session. Progress was friendly enough to back out any open
transactions so nothing was affected.
Terry L. Williams 176 Shadywood Circle Cranberry, PA 16319
814-676-8650 tlw@... <mailto:tlw@...>
Sent: Friday, April 25, 2003 5:04 PM
1135 Aviation Place
USA
Fax 818-898-2236
E-mail: miket@...
> minutes?
it
> Patrick
> Hi all,
> Thanks,
> John Mansfield
> General Sheet Metal
have
enable access. )
<http://rd.yahoo.com/M=247865.3003379.4507215.2595810/D=egroupweb/S=17050071
83:HM/A=1482387/R=0/*http://ads.x10.com/?bHlhaG9vaG0xLmRhd=1051304696%3eM=24
7865.3003379.4507215.2595810/D=egroupweb/S=1705007183:HM/A=1482387/R=1=10513
04696%3eM=247865.%20>
