Program opens…and the wheel spins and spins and spins…does finally load in one site but not the other two where the most receiving activity occurs. We ARE able to receive by filling in a Pack number and hitting TAB or ENTER…lines for the pack come up then…so we’re not entirely dead in the water.
Have an EpicCare case open, seems to be going by the playbook so far. (EDIT 3 - just gave up and closed it.)
No personalizations on mine - deleted everyone else’s as precaution. Tried their “application studio” reset (load base layer, exit). No dice. No associated BPMs at method level. Only one at data level is on TFOrdDtl.Update (so that wouldn’t come into play on an initial screen load). Their latest recommendation was a data model regen, recycle-app-pool and an IIS reset…which doesn’t seem to match up to previous screen-load issues we’ve had.
Anyone ever see this before?
EDIT 2: not only does the entry of the pack number work…but the basic search function will let you call up any pack with a “not received” status, check it off and receive it.
It’s just on the initial load coming in from the menu where the wheel goes round and round.
I’d like to think the laughing minions GIF is about you having to put in a BPM in the first place. At least you had the ingenuity to block it from blowing up. Kudos.
