Recommendations for "smart" scanners
*bump*
Also, some clarification:  I am looking for document scanners (for receivers, etc. to tie into document management workflows), rather than handheld scanners (i.e. for barcode reading).  Thanks in advance.
Regards …
Shaun W M Scott
Senior Systems Analyst - MRP
Sent: Tuesday, December 2, 2014 2:58 PM
Subject: Recommendations for "smart" scanners
Hello.  I am fishing for scanner suggestions, as I need to find an industrial, faster solution for the Scan Station I currently manage while retaining some of that unit’s abilities (e.g. one-touch scanning; ability to create folders and filenames within previously set directories; blank/white page detection).
Thanks and regards …
Shaun W M Scott
Information (including any attachments) contained in this electronic transmission is a PRIVILEGED AND CONFIDENTIAL COMMUNICATION. It is for the sole use of the sender and the entity named above. If you received this electronic transmission in error, you are required to immediately delete it in its entirety without making a copy. Further dissemination is absolutely prohibited. Thank you.   ­­
Shaun W M Scott
