Actually it is a programming fix, but only if you have source code.
There are a number of ways to deal with this situation programmatically,
and the approach you choose will depend on decisions that were made a
design time.
Not much help here, but it might be something to raise as an enhancement
request.
Lydia Coffman wrote:
Specialists in Progress Databases and Software since 1986
William E. Colls william@...
PROComputer Systems Tel 613 591 0079
67 Willow Glen Dr. Fax 613 591 3924
Kanata Ontario Canada www.procomsys.com
K2M 1T1
design time.
request.
> I know, I'm behind again, but just wanted to add something to this thread:
> When that box pops up, it tells you who is using the record (Record in use
> by Lydiac on 41, for example).
> Call the person using the record, ask them to close that screen (90% of the
> time, they're done anyhow) -then POOF! The message disappears. You are
> good to go.
> This IS a feature. Record locking is a good thing. It keeps me from
> changing something at the exact same moment someone else is changing it,
> thus creating a mess in the database. Believe me that you don't want to
> exist in a complex database without it.
> I do agree, though, that there ought to be a way to just exit that screen or
> module gracefully, not dump you unceremoniously out of Vantage. That is
> probably a Progress fix, though.
> Lydia
> -----Original Message-----
> From: Mark Dupuis [mailto:dupuism@...]
> Sent: Monday, January 07, 2002 7:17 AM
> To: vantage@yahoogroups.com
> Subject: RE: [Vantage] record in use
> I think when a program boots you out when you do not want to be you have a
> problem. When I called support on this I was told this is an added feature.
> They have no plans of fixing it.
> Mark Dupuis
> Ranor Inc.
> From: LISA RICCI [mailto:lricci@...]
> Sent: Monday, January 07, 2002 10:02 AM
> Subject: [Vantage] record in use
> Is there any way to avoid being dumped from Vantage when a user attempts
> to access a record that is in use? A message appears that appears to
> give you the option to cancel and wait for the record to be available,
> yet when the second user chooses this option Vantage closes and we have
> to disconnect the user using mprshut.exe
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.
> (2) To search through old msg's goto: http://groups.yahoo.com/group/vantage/messages
> (3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/links
K2M 1T1
