Record Not Found Error
Okay, for saying you don’t know too much you sure sent a lot of good information. From your info this is what I have so far:
			UD110exists = false;
			morePages = false;
			System.Data.DataSet dsUD110;
			try
			UD110Adapter adapterUD110 = new UD110Adapter(this.oTrans);
			adapterUD110.BOConnect();
			string Key1 = "PMOPERATIONS";
			string Key2 = tbTypeCode1.Value.ToString();
			string Key3 = tbFreqCode1.Value.ToString();
			string Key4 = tbEquipTypeID.Text;
			string Key5 = string.Empty;
			string wClause = "Key1 =  ' " + Key1 + " ' and Key2 = ' " + Key2  + " ' and Key3 = ' " + Key3 + " ' and Key4 = ' " + Key4 + " ' and Key5 = ' " + Key5 + "'";
			MessageBox.Show(wClause.ToString());
			opts.NamedSearch.WhereClauses.Add("UD110", wClause); ////Error Here
			MessageBox.Show("Before getting the Data Set");
			dsUD110 = adapterUD110.GetRows(opts, out morePages);
			MessageBox.Show("After getting the Data Set");
			if(dsUD110.Tables["UD110"].Rows.Count > 0)
				UD110exists = true;
				adapterUD110.Dispose();
	catch (System.Exception ex)
		ExceptionBox.Show(ex);
That code works perfectly if a record exists and it sets the UD110 exists to true accordingly.
However, if a UD110 record doesn’t exists I am getting an error where I have shown it in the code. Attached is the error.
Any ideas?
@utaylor @josecgomez
