Refresh part quantities and allocations error
How do I resolved this error so that I can run “refresh part quantities and allocations”?
Error:UOM conversion factors are zero for some parts. Please review and correct before continuing.
Have you already tried any queries to locate possible sources?
e.g. tables Part, PartUOM, UOMClass, UOMConv, etc…?
I think you can filter the parts selected. So run it on various parts to find the offending part.
And the root cause is most likely the creation of a part with a PartNum previously used as a POTF
Any updates on this? How did you get it resolved?
I am running into the same issue.
I am having the exact same issue as well. Would love if it if you could update the thread on if you found a solution. Thanks!
