Hello,
In Epicor 10.1.500.11 is there a way to remove a company from a user via DMT.
For example,
User A has company 1 and company 2 assigned to their user account, and I want to use DMT to remove company 1 only.
Hello,
For example,
Hi Jeff,
I am in a single company environment, so not 100% sure if this will work. But I believe that the following would do.
Within the DMT set the “UserComp#Company” field to the company to remove the user from.
Then run DMT with the “Delete” option set.
Best of luck!
