Remove duplicates from a semi colon delimited string
Hi Everyone,
I am writing a BPM , part of which is creating a comma delimited string of email addresses. This is working as it should but can have a number of duplicates. Eventually this string is placed in the ‘To’ field of the email widget. I would like to remove the duplicates and have tried using ‘Distinct’ and ‘Split’ but I just keep getting errors. Do I need to add something in ‘Using’ or ‘References’ to do this?
SalesRep = (from SalesRep_Row in Db.SalesRep
    						where (SalesRep_Row.Company == Session.CompanyID
        				&& SalesRep_Row.SalesRepCode == salesRepCode)
    						select SalesRep_Row).FirstOrDefault();
								if (SalesRep != null)
									if (emailRecipients == "")
											emailRecipients = SalesRep.EMailAddress;
									else
											emailRecipients = emailRecipients + "; " + SalesRep.EMailAddress;
								callContextBpmData.Character03 = emailRecipients;
								msg = "Email Recipients are " + emailRecipients;
								this.PublishInfoMessage(msg, Ice.Common.BusinessObjectMessageType.Information, Ice.Bpm.InfoMessageDisplayMode.Individual, "SalesRep", "Update");
Thanks in advance
Adrian.
Hi, try this:
var l = "text1;text2;text3;text1;text4;text1".Split(';').ToList();
var qry = l.GroupBy(x => x).Select(y => y.FirstOrDefault());
foreach(var o in qry)
	Console.WriteLine(o);
Output:
text1
text2
text3
text4
Thanks @carlosqt, used your suggestion and ended up with this, which works how I want it to
									else
											emailRecipients = emailRecipients + "," + SalesRep.EMailAddress;
											var sendTo = emailRecipients.Split(',').ToList();
											var qry = sendTo.GroupBy(x => x).Select(y => y.FirstOrDefault());
											var result = String.Join(",", qry);
											emailRecipients = result;
Thanks Adrian.
