Removing Panel Grid DropDown Filter
Hey, I want to remove / hide a dropdown filter on a panel grid. I’ve tried a couple things, but haven’t found a way to do it in the panel properties. The dropdown itself isn’t its own component, so I can’t set its properties separately. Any thoughts?
I just ran into this … again.
The only way I’ve been able to get rid of it is to delete the panel grid and recreate it - and then do not touch the View Options menu, because just opening it leaves this empty View selector.
I had that thought but was really hoping someone had an alternative, but if them’s the breaks…
Anytime you feed information in the Panel Card Grid > Advanced > View Options this will happen :grimacing:. What is actually happening is that you’re telling Application Studio that your grid has different Views, therefore, it generates a dropdown for you to select as many views as you have created.
:point_right:If you want one grid only, instead of feeding the grid with info under View Options, you should go to Data > Grid Model > Provider Model.
To get rid of it you can delete whatever BAQ is in the View Options.
TLDR:If you don’t need the dropdown use only the Grid Model > Provider Model and delete anything in View Options. :rotating_light:
