Our marketing department needs to be able to keep track of customers by the campaign they were sourced from. I’d like to use the same MktgCamp and MktgEvnt tables that are used on QuoteHed, but I’m still new to this and can’t figure out how to correctly populate a combobox with the events for just the selected campaign. I know this will require some custom code but I don’t for the life of me know where to start.
Right now here’s what I’ve got working:
- I have a combobox for the Campaign (instead of a search button like appears in Opportunity/Quote Entry) in Customer Maintenance.This correctly lists all available campaigns from the MktgCamp, displaying the description and returning the campaign ID.
- I have a combobox for the Event (again, no search button - I would like to try and keep it that way). This currently lists all events from the MktgEvnt table, rather than just the events matching the MktgCampaignID.
As I said, I’m hardly sure where to even start. An event on BeforeDropdown? But then how to query the table/view for the right values and populate the field?
Thank you for any help.
