Replicating trial balance in BAQ
Hi there,
I’m new to Epicor kinetic and I’m trying to replicate the Trail balance in BAQ so I can make a Data Discovery Chart to show the Trial Balance from YTD or even more preferable until a chosen date. Does anyone has a solution for this or am I trying to creat something that will not happen..?
I’ve not made a BAQ for trial balance but there is a thread with a BAQ which should help you get started. If you’re not using dynamic segments it may be good to go but I’d try to fix it either way just incase.
I know I have build a trial balance with a BAQ.
I will go look in my garage or basement, I know it’s around here somewhere.
Thank you Randy, I’ve tried to fix this BAQ but I’m not getting there. Nice thing about this BAQ is that it asks for begin and end period. I’ve already made this BAQ earlier but it’s also not exactly what I was looking for.
GLaccountsYTD.baq (11.0 KB)
Did you find it in your basement?
Checking the attic now
Maybe by tomorrow
Found it…behind a trunk.
Note that I had this modified for a special approach, but it may get you going in the right direction.
The dashboard retrieves all periods and filters the balances.
TrialBalance_4.baq (46.4 KB)
TrialBalance_4.dbd (102.0 KB)
