At 01:09 PM 10/18/2002 -0400, you wrote:
points to a directory that the user does not have write access to. This is
normally the case for the start menu items created by the client install in
the Progress and Vantage, since your end users *should not* have write
access to the shared drive.
Use the Report Builder icon created in the Progress menu, not Vantage, and
edit its properties so "Starting In" points somewhere writable.
-Wayne Cox
Twenty Three - Information Technology Consulting
828-685-2338
>When I try to run Report Builder I get an error saying: "Prorb32.exe hasI think this happens if the shortcut / menu item you're starting it from
>generated errors and will be closed by windows. You will need to
-Wayne Cox
828-685-2338
