OK...I've created a report for all the ship-to addresses in the system.
Sales Dept would like it in an Excel spreadsheet. I'm having problems
exporting it to Excel. When I choose the Export command from the Report
drop-down, it doesn't keep the "columns" over in Excel. If I choose
Fixed-Length, it "blends" columns. I can't utilize Delimited because the
only "option" I can think of is "space" and that also messes up my columns.
Any suggestions???????
TIA!!
Tricia Simon, Controller
Riten Industries, Inc.
800-338-0027, ext. 2205
Tricia, You will most likely have to add a delimiter field
between each column. Try a comma, semi-colon, >, etc.
I frequently have two reports one for viewing
another for exporting with EXPORT added to the report name.
Sent: Tuesday, March 25, 2003 8:37 AM
To: Vantage One-List (E-mail)
Subject: [Vantage] Report Builder export question
TIA!!
I place a unique character at the beginning of each field such as an "@" or
a "#" and then I use that as the delimiter when importing the text file into
excel. Works fine.
Bob Goss
BC Instruments
Sent: Tuesday, March 25, 2003 9:37 AM
TIA!!
I rarely use report builder when I need to export data because of these
issues. You can use the export utility, crystal reports, or ODBC with Excel
or access to get the data into excel in a nice, clean format. However, if
you want to use report builder, here's what I've done in the past. Make a
copy of the report and between each field, enter a ~. Merge left all the
fields. Delete everything from your report (all header's, page footers,
etc.). Then after you export it, when you pull it into excel, ~ will be the
delimiter. Comes in relatively clean like this.
Tricia,
One method others have used is to embedd a special character in the
report between each column. For instance, use the | (shift of the \ key).
Then you can use that character when importing to Excel as the column
delimiter.
Troy Funte
Liberty Electronics
TIA!!
