Troy,
That solved the issue. I went into progress startup.pf, and added the
parameter. As is turned out, there was not a parameter setting in the
progress file.
Thanks Again,
Pablo Garza
Sent: Thursday, October 11, 2001 7:51 AM
Subject: Re: [Vantage] Report Builder Link
There are two files which set the -Mm size (which is the packet size for
data being transmitted from the server to the client workstation).
One file (N:\progress\startup.pf) is where Progress gets the Packet size for
the server. This can also be set in your startup command (in ProControl) or
in the -Mm field in Progress Explorer tool. From your error message, the
server has a -Mm of 4096. This is what it should be.
The other file (N:\Vantage\Db\vantage.pf) is the file your client uses for
setup information. There should also be a -Mm setting here which matches
your -Mm above. If there is no -Mm there, it probably defaults to 1024.
Add a -Mm 4096 to a line in that file. (Use Notepad to edit the vantage.pf
file).
This should fix your problem.
Troy Funte
Liberty Electronics
progress file.
Thanks Again,
Pablo Garza
file).
Troy Funte
Liberty Electronics
----- Original Message -----
To: 'vantage@yahoogroups.com'
Sent: Wednesday, October 10, 2001 7:52 PM
Subject: [Vantage] Report Builder Link
Per the advice I received, we were able to build report links within
Vantage. However, the following errors occurred:
Unable to connect to database. Database error is: server has -Mm parm 4096
and client has 1024. They must match (1150)
Is there a switch setting I should be addressing??
Any assistance would be appreciated.
Pablo Garza
Dix Metals, Inc
Yahoo! Groups Sponsor
<http://rd.yahoo.com/M=212180.1660613.3195489.1269402/D=egroupweb/S=17050071
83:HM/A=812074/R=0/*http://www.verisign.com/cgi-bin/go.cgi?a=b15334027000300
0>
<http://us.adserver.yahoo.com/l?M=212180.1660613.3195489.1269402/D=egroupmai
l/S=1705007183:HM/A=812074/rand=693070181>
