The VTG file is the problem. It probably references things
that your citrix/terminal server doesn't have access/mappings
to. Is the L Drive mapped when you use Citrix? Yo can
Make another copy of the VTG file, and change it so that
the references all work for the Citrix environment. The main one
that we had to change for Vantage and Report builder was the
temp directory, to the Users Terminal server home directory.
Good Luck,
Tim Care
Electro Chemical Finishing
Good Luck,
Tim Care
----- Original Message -----
To: <vantage@egroups.com>
Sent: Friday, October 06, 2000 1:22 PM
Subject: [Vantage] Report Builder through Citrix.
> When I try and publish Report Builder, when the users launch - they get
> error(193) occurred while creating user logon. Failing component:
> "L:\Vantage\Report Builder.vtg" and it quits. Has anyone come across
> this before? thanks.
> Gary Buck
> IS Network/Systems Administrator
> Tech Mold, Inc.
> gary.buck@...
> We no longer allow attachments to files. To access/share Report Files,
> (Note: If this link does not work for you the first time you try it, go
to www.egroups.com, login and be sure to save your password, choose My
Groups, choose Vantage, then choose Files. If you save the password, the
link above will work the next time you try it.)
