Help,
I am trying to upgrade to 700 level, and i am running into an issue while printing invoices. I have searched for the answer and what i have read I cannot seem to fix. Can someone please help me.
Program Ice.Services.Lib.RunTask raised an unexpected exception with the following message: RunTask:
System.ArgumentException: Column ‘Calc_TotalAdvBillCred’ does not belong to table InvcHead.
at System.Data.DataRow.GetDataColumn(String columnName)
at System.Data.DataRow.set_Item(String columnName, Object value)
at Erp.Internal.AR.ARInvForm.SetColumnValues(String tableName, DataRow row) in C:_releases\ERP\ERP10.2.700.40\Source\Server\Internal\AR\ARInvForm\ARInvForm.cs:line 5338
at Ice.Core.RptTaskBase1.RunSetColumnValuesProcess(String tableName, DataRow row) in C:\_releases\ICE\ICE3.2.700.40\Source\Server\Internal\Lib\TaskLib\RptBase\RptTaskBase.cs:line 212 at Ice.Core.RptBase.ReportRowDataWriter.WriteRow(IRow row) in C:\_releases\ICE\ICE3.2.700.40\Source\Server\Internal\Lib\TaskLib\RptBase\ReportRowDataWriter.cs:line 65 at Erp.Internal.AR.ARInvForm.RunProcess(Int64 instanceTaskNum, String outputFileName) in C:\_releases\ERP\ERP10.2.700.40\Source\Server\Internal\AR\ARInvForm\ARInvForm.cs:line 1315 at Ice.Core.TaskBase1.StartProcess(Int64 instanceTaskNum, String outputFileName) in C:_releases\ICE\ICE3.2.700.40\Source\Server\Internal\Lib\TaskLib\TaskBase\TaskBase.cs:line 83
at Ice.Hosting.TaskCaller.InnerExecuteTask(IceDataContext newContext) in C:_releases\ICE\ICE3.2.700.40\Source\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 117
at Ice.Hosting.TaskCaller.ExecuteTask() in C:_releases\ICE\ICE3.2.700.40\Source\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 59
at Ice.Lib.RunTask.BpmFriendlyTaskLauncher.Run(String sessionIdPrefix, IceContext db, Action taskRunner) in C:_Releases\ICE\ICE3.2.700.0\Source\Server\Services\Lib\RunTask\BpmFriendlyTaskLauncher.cs:line 63
at Ice.Services.Lib.RunTaskSvc.InnerRunTask(Int64 ipTaskNum, Boolean suppressTransaction) in C:_Releases\ICE\ICE3.2.700.0\Source\Server\Services\Lib\RunTask\RunTask.cs:line 454
