A Requisition entry i was workimg on has been accidentally set to closed. Is it possible to reopen the req or will i have to create a new one and add the lines again
Pinging @Mark_Wonsil and @ckrusen
We dont use requisitions, so i cant help.
But if you do have to recreate it, try using copy and paste to recreate the lines.
Like Calvin, we’ve found requisitions not fitting our company’s workflow, so we haven’t started using it yet either.
Hi Darren,
I do not believe there is any way to reopen a closed Requisition. You could do a copy all of the lines on the closed one (via Lines / List tab) and a paste insert to new Req, as a shortcut if you have many lines.
Nancy
