Sorry Merri. Misunderstood the question.
Limiting requisitioner to a max amount is not native that I know of. (We don't use requisitions in this manner however so I could be dead wrong.)
You could probably write a customization to do it... All depends upon what your physical process for requisition entry is. If you can rely upon the fact that the logged in user is really the requestor (that may have some max limit you want to enforce), you would have a good chance of success at a fairly simple customization. You would however then have to add a maintenance function in user maintenance to keep max requisition values per user current (stored in a ud field).
Hope that helps.
Rob
Hope that helps.
Rob
--- On Tue, 11/25/08, Merri Larson <merri.larson@...> wrote:
Subject: Re: [Vantage] Requistion approvals
Date: Tuesday, November 25, 2008, 12:28 PM
Thanks Robert. We understand the buyer approval dollars. Is there a way to set limits for the requisitioner? Thanks for any insite you can share.
To: vantage@yahoogroups .com
Date: Monday, November 24, 2008, 6:16 PM
Yes. In Buyer set up, you can indicate a max $ self-approval limit.
--- On Mon, 11/24/08, merri.larson <merri.larson@ yahoo.com> wrote:
Subject: [Vantage] Requistion approvals
Date: Monday, November 24, 2008, 9:36 AM
Is there a way to control approvals by dollar amount? Different
positions have different approval levels. Can this be controlled?
