Rest-erp -- how to properly pass ds
Hi there,
I am attempting to create a switch between report styles based on a parameter - I am struggling to properly pass ds through the rest-erp BAQReport.TransformAndSubmit call.
Copying the exact rest-erp component from the locked system event does not pass anything in ds and breaks the rest call - they don’t even define ds in the method parameters or request parameters etc.
I am unsure of how to properly get ds across, especially since dataviews don’t necessarily match.
Current dataviews I am working with:
Correct payload that I am looking for:
Current payload and ds parameter:
I have also tried the regular rest component but am unfamiliar with this. I have also tried leaving ds blank the same way that the Epicor system event does with no luck. Any help is greatly appreciated!!
Solution found:
I am creating a new ds and manually updating the values with row-update
value:
rest call:
This has worked and has successfully generated my report as expected.
Better Solution Found:
Build ds using a function with Epicor Functions Maintenance.
Response Parameter type = System.Data.DataSet
Input parameters = anything you need to set dynamically. For example:
Response parameter for your custom ds can be inserted directly into the rest call with actionResult.yourParam
*haven’t yet changed the param name from json to something more fitting - I was first attempting this with serialized json
Payload is perfect!
