Is there a template example or writeup for creating a .Net Web App / Front End that hooks to the Epicor REST API ? I find scattered pieces. Am looking for guidance in the VS settings / NuGet downloads / Authentication / Sample Code to build a Web Page that retrieves Epicor data upon a button click on Custom Web Page via REST Api calls. Displaying results to Web user. So many diff options / paths hard to visualize which ones I need to put together to make this work. Quickly fall down rabbit holes. Know I have used wide brush strokes , but need an aerial view to start / get big picture. Any guidance / examples very much appreciated.
Your quickest path to success probably lies in @josecgomez & @jgiese.wci 's library.
(I think this is the current thread.)
I and a few others have many posts on how to do it the more manual way as well.
Also there are examples in the help, search for REST.
Thanks guys. Will look at these suggestions.
The easiest way is to put all the required functionality into a function and then the only rest API interaction is a call to the function, which is pretty straightforward, if you take the CURL info from Swagger.
