Paul,
Thanks so much. That did the trick. Seems so simple. I figured it had to be a process but I think I would have been looking all day that one.
Jeff
Jeff
--- In vantage@yahoogroups.com, Paul Wetherington <pwetherington@...> wrote:
> Jeff-
> You will need to block access to the JobTraveler process (Rpt.Job Trav) under Process Security Maintenance. On this screen you allow and disallow access to report generation, as well as several other processes within Vantage.
> Thanks
> Paul
> [cid:image001.png@...]
> [cid:image002.png@...]
> This message (including any attachments) is intended only for the use of the named addressee(s), and may contain information that is legally privileged, confidential or exempt from disclosure under applicable law. If you are not a named addressee, you are hereby notified that any use, dissemination, distribution or copying of this message is strictly prohibited. If you have received this message in error, please notify the original sender immediately by telephone or by return E-mail and delete this message, along with any attachments, from your computer. Thank you.
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of jplehr
> Sent: Friday, July 08, 2011 2:52 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Restrict Printing
> Vantage 8.03.409C
> I have a need to restrict printing of the Job Traveler. I know I can limit the view through Menu Maintenance, but what is needed to control who can print the Job Traveler from all the different areas?
> Jeff
