Does anyone know how to reverse a production build for a part number that is marked as both Serial Number tracked and Lot Tracked. I have uncovered a number of jobs that reported production against a job in error, and I need to reverse the production to take the Inventory out of finished goods and put everything back into WIP. Normally (for un-serialized part number production), I would go into Time&Expense and enter a Negative Quantity against a job, and everything reverses quite nicely. When I try to do this on our serialized products, it requires me to select a Serial Number, but since the Serial Number is in a Status of “Inventory”, it is not available for selection. I have tried overriding the Serial Status to WIP/Available/etc, and it still throws up a hard stop. I thought I figured it out by doing a Negative “Job Receipt to Inventory”, but this just put the value of the finished good to a variance GL Control, and left the quantity in inventory, causing my GL and Sub-Ledgers to be out of balance.
In summary, how do I reverse an accidental production entry against a job that creates a Serialized and Lot Tracked part number? Thanks in Advance
