I have a BPM which correctly processes an * RMA Disposition To Job *. Using the same methodology, my RMA Disposition To Stock fails to update correctly. The RMA Disposition data is saved, but the Receipt record is not updated with the disposed qty.
Any ideas why the BPM code bbelow does not woek?
The same process in a customisation also works absolutely fine. I have tested on 10.2.500.11 and 10.2.200.18.
RMA Dispose To Job
/*CODE TO DISPOSE RMA RECEIPTS TO JOB*/
if (tDr["Calculated_MassRMAProcess"].ToString().Length > 0 )
fRMA = tDr["Calculated_MassRMAProcess"].ToString();
writer.WriteLine(System.DateTime.Now.ToString() + " Validate Job number for disposition " + fRMA );
var dJob = (from ddJob in Db.JobHead where ddJob.Company == callContextClient.CurrentCompany && ddJob.JobNum == fRMA select ddJob).FirstOrDefault();
if (dJob != null)
writer.WriteLine(System.DateTime.Now.ToString() + " Job exist for disposition " + fRMA );
Erp.Tablesets.RMADispTableset tsRD = new Erp.Tablesets.RMADispTableset();
Erp.Contracts.RMADispSvcContract rd = Ice.Assemblies.ServiceRenderer.GetService<Erp.Contracts.RMADispSvcContract>(Db);
if(rd != null)
tsRD = rd.GetByID(rmaNum, rmaLineNum,rmaRNum);
writer.WriteLine(System.DateTime.Now.ToString() + " Get new RMA disposition for the job" + fRMA );
rd.GetNewRMADisp(ref tsRD,rmaNum, rmaLineNum,rmaRNum);
var ttnRD = (from ttnRD_r in tsRD.RMADisp where ttnRD_r.RowMod == "A" select ttnRD_r).FirstOrDefault();
if (ttnRD != null)
writer.WriteLine(System.DateTime.Now.ToString() + " Prepopulate disposition data for the job " + fRMA );
ttnRD["DispType"] = "INS-MTL";
ttnRD["JobNum"] = fRMA;
ttnRD["InspectedBy"] = "QUAL21";
ttnRD["DispQty"] = ttRMARcpt.ReceivedQty;
ttnRD["EnableBin"] = true;
ttnRD["MtlSeq"] = 0;
ttnRD["RequestMove"] = false;
rd.Update(ref tsRD);
writer.WriteLine(System.DateTime.Now.ToString() + " Disposition data updated for the job " + fRMA );
RMA Dispose To Stock
if (Convert.ToBoolean(tDr["Calculated_Dispose"]) == true)
if(!Convert.IsDBNull(tDr["RMARcpt_RMAReceipt"]))
rmaRcpt = Convert.ToInt32(tDr["RMARcpt_RMAReceipt"]);
else
rmaRcpt = Convert.ToInt32(tDr["Calculated_MassRMAProcess"]);
pNum = Convert.ToString((tDr["RMADtl_PartNum"]));
rmaNum = Convert.ToInt32(tDr["RMADtl_RMANum"]);
rmaLineNum = Convert.ToInt32(tDr["RMADtl_RMALine"]);
var tPartRev = (from ttPartR in Db.PartRev where ttPartR.Company == callContextClient.CurrentCompany && ttPartR.Plant == callContextClient.CurrentPlant
&& ttPartR.PartNum == pNum && ttPartR.Approved == true && ttPartR.Method == true orderby ttPartR.EffectiveDate descending select ttPartR).FirstOrDefault(); // check making part exist
if (tPartRev != null)
var ttRMARcpt = (from ttRMARcpt_r in Db.RMARcpt where ttRMARcpt_r.Company == callContextClient.CurrentCompany && ttRMARcpt_r.RMANum == rmaNum &&
ttRMARcpt_r.RMALine == rmaLineNum && ttRMARcpt_r.RMAReceipt == rmaRcpt select ttRMARcpt_r).FirstOrDefault(); // check RMAReceipt exists
if (ttRMARcpt != null)
if(rd != null)
tsRD = rd.GetByID(rmaNum, rmaLineNum,rmaRcpt);
rd.GetNewRMADisp(ref tsRD,rmaNum, rmaLineNum,rmaRcpt);
if (ttnRD != null)
string cMessage;
whse = ttRMARcpt.WareHouseCode.ToString();
bin = ttRMARcpt.BinNum.ToString();
decimal dispQty = (decimal)ttRMARcpt.ReceivedQty;
rd.ChangeDispType(ref tsRD, "INS-STK", out cMessage);
rd.ChangeWarehouse(ref tsRD, whse, out cMessage);
rd.ChangeBinNum(ref tsRD, bin);
ttnRD["ToWareHouseCode"] = whse;
ttnRD["ToBinNum"] = bin;
ttnRD["DispQty"] = dispQty;
ttnRD["DispQtyUOM"] = "EA";
ttnRD["InspectedDate"] = DateTime.Now;
ttnRD["ReasonCode"] = "";
ttnRD["SetReassignSNAsm"] = false;
ttnRD["EnableInspectedBy"] = true;
ttnRD["RequestMoveLicense"] = true;
ttnRD["EnableInspection"] = false;
ttnRD["RowMod"] = "A";
Db.Validate();
rd.Dispose();
dspRowCount += 1;
writer.WriteLine(System.DateTime.Now.ToString() + " Dispose Complete for " + txtRMA);
writer.WriteLine(System.DateTime.Now.ToString() + " **** Dispose Count = " + dspRowCount.ToString() );
} //if (ttnRD != null)
} // if(rd != null)
}//if (ttRMARcpt != null)
}//if (tPartRev != null)
