RMA disposition in 809
Hi,
We experienced the same issue that Vishal described below. It was a
bug that Epicor was aware of in May 2006 and they sent us a
patch/fix that did not work so we had to manually correct these
duplicates. Epicor told us that the general ledger would not be
affected (only quantities duplicated) and so no cost adjustment
would be needed. However, we are now experiencing $ reconciling
issues and I'm wondering if the general ledger was affected?
Did anyone on this board have the same issue?
Vanessa
--- In vantage@yahoogroups.com, "Vishal Mehta" <vishy65@...> wrote:
> We are on 809 and are observing that there is a bug in Disposition
of returns. When we disposition to Stock and assign different
warehouse ( FG) ( returns are received in MRB warehouse); system is
doubling inventory in warehouse returns were received ( MRB) and not
moving to destination warehouse.
> Is anyone else facing this issue ? According to Epicor support ;
its not an issue and its specific to our DB .
> Vishal
We are on 809 and are observing that there is a bug in Disposition of returns. When we disposition to Stock and assign different warehouse ( FG) ( returns are received in MRB warehouse); system is doubling inventory in warehouse returns were received ( MRB) and not moving to destination warehouse.
Is anyone else facing this issue ? According to Epicor support ; its not an issue and its specific to our DB .
Vishal
Are you multi-plant?
> Vishal
No, we are single plant.
Vishal
To: vantage@yahoogroups.comFrom: mhow@...: Tue, 12 Sep 2006 21:24:46 +0000Subject: [Vantage] Re: RMA disposition in 809
Are you multi-plant?--- In vantage@yahoogroups.com, "Vishal Mehta" <vishy65@...> wrote:>> We are on 809 and are observing that there is a bug in Disposition of returns. When we disposition to Stock and assign different warehouse ( FG) ( returns are received in MRB warehouse); system is doubling inventory in warehouse returns were received ( MRB) and not moving to destination warehouse.> > Is anyone else facing this issue ? According to Epicor support ; its not an issue and its specific to our DB .> > Vishal > > [Non-text portions of this message have been removed]>
We are considering installing 809, but we also use RMA's and return to
different warehouses and bins. Is anyone doing that successfully?
Thanks for you help.
<http://www.coldjet.com>
Michelle de la Vega
Business Applications Manager
Cold Jet, LLC
455 Wards Corner Road
Loveland, Ohio 45140
513-716-6400
513-831-1209 FAX
Celebrating 20 Years of Dry Ice Technology and Innovation
Of Vishal Mehta
Sent: Tuesday, September 12, 2006 4:37 PM
Subject: [Vantage] RMA disposition in 809
Vishal
