Anyone who uses Role Codes seeing this behavior that after you create a role code and then assign it somewhere that it shows the record twice in Role Code Maintenance landing page? I also discovered that if the company configuration is set to employee for default location of labor booking, then in Time Entry for project time the role dropdown also shows two entries (or when adding the role to the employee record). However, when I query the table, there’s only a single record and if I do anything with either of the entries in Role Code Maintenance the change happens to the other, confirming that it’s a single record.
I’m not seeing this at the moment (2024.2.12) but have seen this type of duplication in other places. I would report it - maybe its fixed in a later release.
