Rounding clock punches in Vantage
--- In vantage@yahoogroups.com, "Tom" <tombosko@...> wrote:
> --- In vantage@yahoogroups.com, "jreader1977" <jreader1977@> wrote:
> > Hi,
> > Does anyone have a method for rounding clock punches in Vantage
> 8.03?
> > I know there is an option under Company Maintenance for Clock In
> > Allowance time and Clock Out Allowance time that does this if you
are
> > so many minutes within the shift, but I would like to be able to
> round
> > every punch, even if they are late or outside their shift time.
For
> > those who have Open4 is there an option to apply rounding rules
> within
> > that module?
> > Thanks,
> > Josh Reader
> > Mercury Electronics
> Josh,
> I have the same situation as you. You must contact the Open4 folks
to
> write rules that work in conjunction with the import utility for
> Vantage within Open4. No, nothing in Open4 to round.
> Also make sure your labor codes match in each system so they can be
> imported correctly in Open4 as the detail time records are
imported.
> Note I said detail and not header only info for the import.
> Open4 folks have writtem many rules to accomodate these types of
> requests.
> Tom Bosko
> Miner Enterprises
Thanks for the info Tom! We are doing a WebEx demo of Open4 next
week so this will help me to ask the right questions and give me some
insight.
Josh Reader
Mercury Electronics
Hi,
Does anyone have a method for rounding clock punches in Vantage 8.03?
Allowance time and Clock Out Allowance time that does this if you are
so many minutes within the shift, but I would like to be able to round
every punch, even if they are late or outside their shift time. For
those who have Open4 is there an option to apply rounding rules within
that module?
Josh Reader
Mercury Electronics
--- In vantage@yahoogroups.com, "jreader1977" <jreader1977@...> wrote:
> Hi,
8.03?
round
within
> that module?
> Thanks,
> Josh Reader
> Mercury Electronics
Josh,
I have the same situation as you. You must contact the Open4 folks to
imported correctly in Open4 as the detail time records are imported.
requests.
Tom Bosko
Miner Enterprises
I am rounding using an old Crystal report, that payroll uses for ADP
manual data entry.
I would like to eliminate the need for rounding and make the attendance
portion of data collection only available for short intervals i.e. 5
minutes at shift starting and ending times. Is this something that might
be possible using a BPM?
Dan Shallbetter
States Electric Mfg.
Of Tom
Sent: Tuesday, September 09, 2008 11:24 PM
Subject: [Vantage] Re: Rounding clock punches in Vantage
> Hi,
8.03?
round
within
> that module?
> Thanks,
> Josh Reader
> Mercury Electronics
Josh,
requests.
Tom Bosko
Miner Enterprises
